Question about Daewoo DTQ-20U4SC 20" TV
The tv screen has reduced in height ,how to increase it's height
  • 70 Answers
Deu to vertical amp problem pls check the vertical out put ic
Posted on Aug 27, 2010
Cs-21m16ml tv has lines lower half of screen and screen height slightly reduced and non linear. help
You're losing your high voltage to the picture tube. Have it checked at a repair shop. The voltages present on the tube will knock you on your a** if you're not careful.
Nov 17, 2014 | Televison & Video
Tip
Step Up Height Increaser
Step Up Height Increaser is an natural and herbal supplements. it is increase a height & Strength body and also develop memory. step up height is more efficient to immune and digestive system. it is increase self confidence.
Step Up Height Increaser Ayurvedic Herbel Height Growth Formula
on Aug 19, 2016 | Miscellaneous
Can i go from 14 inch to 15inch tires and rims
If you post your present tyre size (on the tyre wall), then we can offer you a suitable larger replacement diameter size.
The simple answer to your question is yes, you can increase the size of your rims, and lower the profile of your tyre to compensate.
The other thing I'd mention as most people who don't know much about tyres don't consider this, is that when you reduce the height (wall) of a tyre by increasing the rim size, then you change two primary characteristics of the tyre's performance.
1: Tyre wall stiffness. Simply put, the shorter the tyre wall, the stiffer the tyre is when cornering. This can be a positive thing and can reduce the amount of body roll, whilst increasing the tyre's contact with the road.
2: Suspension. The tyre wall offers suspension to the vehicle. Yes, it's not just your springs and shocks which absorb the bumps from the road. By reducing the tyre wall height, you will effectively reduce the suspension capability of the tyre and it will become less forgiving on road surfaces.
It's because of these two reasons above that manufacturers try different combinations to deliver the best overall satisfaction rating to the type of customer who is going to drive that type of vehicle.
It is therefore typical that to many people, changing the rim and tyre size will not always have a positive effect.
In fact most customers who request rim size upgrades, according to my own experience are only interested in the appearance of the wheel, but are often disappointed with the results in performance.
This is why I always find it prudent to mention these points to anyone considering a rim size increase.
Rim size increases, because resulting in less tyre suspension actually increases shocks to the chassis components, and will also tend to reduce the life of these components.
So just be aware of what you face, when making this decision.
Nov 12, 2012 | 1994 Oldsmobile Cutlass Ciera
Are back feet/rollers adjustable?
normally the rear are just rollers
for your problem use tapered door wedges ( hardware shop) under the appropriate side at the rear of the fridge to make the adjustment
Sep 04, 2017 | Electrolux EI23BC51IS
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
VIDEO TAPE WHEN PLAYED WAVE AT THE TOP OF THE TV SCREEN
This is a common problem usually seen when playing copy protected tapes. The part of the picture affected is normally off the top of the screen. Sometimes the problem is also due to the VCR itself and differences in tapes. It's also possible for the TV itself to be causing this, although you would probably also notice this flag-waving (that's what it's called) on regular TV viewing if that were true.
Sometimes increasing the height of the picture can push the affected area off the top again. But this can also cause you to lose part of the picture you want. Also, the height adjustment may be difficult to find as it's not something normally used. On some TV's it's a small pot somewhere on the board, but most newer sets have electronic adjustments through a service menu that you need to know how to access.
I'd suggest trying another VCR first and play one of the tapes you know shows the trouble. That might be all it takes. Then consider trying to increase the picture height if it's just a small bit at the top of the screen.
Mar 12, 2009 | Zenith B25A11Z 25" TV
Hi, i can not wach tv program, the pc screen is too small
hi, reduce the resolution and frequency rate of the graphics card.
Jul 04, 2008 | ASUS Eee 4G Notebook
Mtusbubishi Diamond Pro 900u-I cant seem to adjust to screen in a perfect squre
the best way to adjust is first of all you reduce the height or make picture cinemascope. now from select button agjust vertical & horizontal geomatry now you increase the height as a whole. I think this will solve your problem. you can also refer owener manual if you have it.normally it comes with monitor. good luck/
Sep 29, 2007 | Mitsubishi Diamond Pro 900U 19" CRT...
Daewoo DTQ-20U4SC 20" TV Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
