The keyboard layout has swapped the ' @ ' and ' " ' characters/symbols. Is this a setup or driver issues. Running XP sp 2 Thanks
    President:
  • 2,047 Answers
This is a setup issue. The @ sign and the " ire swapped in the US version and the UK version of keyboards. Depending on the windows which you run you can decide which process to use in changing this. Although it does not pose any problem unless you it is very inconvenient to you.
Hope this solution has been helpful?
Posted on Aug 24, 2010
Testimonial: "Thankyou for your time. "
Why Symbol LS2208 keyboard wedge not scanning correctly?
Do you have more than one of this model scanner? If so, I would test a different one on the same computer to make sure it is not a computer issue. Be sure to test it in the same USB port to get an accurate test.
Having a second scanner would also allow you to switch out the cable connecting the scanner to the computer. The end of the cable which plugs into the scanner is an RJ45/Ethernet end. You will need a flat head screw driver to push down on the tab to release it from the scanner. Swap the cables and see if the problem follows the cable or the scanner. If it follows the cable, you can replace the cable for cheap. If it follows the scanner, I would plug the scanner into the working computer and reset the scanner to factory default using the Symbol Book of programming barcodes.
Try a different USB port with the original scanner.
You can also reset to factory default if you don't have a second scanner using Symbols book of programming barcodes.
Sep 20, 2014 | Symbol LS2208 Handheld
Keyboard mistyping issues
1. Change to United States-International keyboard layout.
Manually change to United States-International keyboard layout
2. Use the Microsoft Fix it 50558
3. Confirm if the Keyboard is wired or Wireless
Information:
Ensure that batteries are new for the wireless keyboards as drained batteries can
cause delay.
Slow computer can also cause the issue. Check if computer is slow and perform necessary troubleshooting steps related to performance after following below provided troubleshooting steps
Steps:
Clear Turn on Filter Keys, or adjust the settings to a quicker rate for Windows Vista and Windows 7
Clear the Use Filter keys check box, and then click OK for XP
adjust your keyboard's repeat delay and rate settings
Drag the Repeat delay: slider to Short
Drag the Repeat rate: slider to Fast
Click OK.
Close all windows
Is issue persists, Reinstall the Drivers
Follow below steps :
http://www.wikihow.com/Fix-a-Keyboard-That-Has-the-Wrong-Characters
Mar 22, 2014 | Dell Inspiron 1525 Laptop
@ key is not eregistering correctly. @ is swapped with " key on keyboard
The standard keyboard language and widely used setting is "ENGLISH (US)"
Set the Keyboard layout to English US so that you have standard keys for symbols etc. like @ sign with SHIFT+2 etc.
The keyboard layout / Language of your PC may have been different (other than English US), so follow these steps to select the International keyboard layout:
- Go to Control Panel - Regional and Language settings
- On the Keyboards and Language tab, click Change keyboards.
- Click Add.
- Expand the language that you want. For example, English (United States).
- Expand Keyboard list, select the United States-International check box, and then click OK.
- In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
- In the Regional and Language Options dialog box, click OK.
The above steps would change the Keyboard Layout settings to 'English US' and you would be able to type @ sign with SHIFT+2
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 18, 2011 | Computers & Internet
The euro symbol is under the 5, how do i type this?
The keyboard shortcut for the € symbol is Alt Gr + 5. However if this does not work, you may also enter the following key combination : Alt+0128.
You have to maintain the Alt key pressed while entering the 0128 code.
Hope this helps you.
Jun 01, 2011 | Acer Computers & Internet
Got an HP Laptop. Need to change language of keyboard to English as when I press a symbol, it brings up an incorrect one.
In the bottom right hand corner of your screen (on the taskbar), you'll see either a symbol of a keyboard (Windows Vista or Windows 7), or two letters together (Windows XP). This symbol represents the language you're currently using for your keyboard. Click on that symbol with your mouse, and select which language you'd like to use (In this case english) to resolve this problem
Mar 05, 2011 | Computers & Internet
Can't seem to get the at symbol working
you may have the keyboard settings to a different 'language' an american layout keyboard is set to have the @ sign as "shift + 2" (whereas the U.K layout would give " for Shift + 2) and vice-versa!
to change the regional settings of your keyboard, (on Xp)
  • Control Panel
  • Regional And Language Options
Under Languages (Second Tab) Click on DETAILS, then this will bring up another window.
Select your default input language as either ENGLISH (U.K) OR ENGLISH (U.S)
Hope this solves the issue!!
sorry if it sounds confusing!
Oct 17, 2009 | Samsung NC10-14ROBL Notebook
Compaq notebook keyboard layout doesn´t match
all HP keyboards, on all 1000s of HP products
all have like 100 keyboards for 100 countries ? sure.
if you read Service GUIDE you'd see that. (p/n for each one)
yes, XP ,
we dont run XP here, in USA, 1% and falling fast.
or get CYBER-ATTACKED, like in the news now in EU.
see the news, why run this VIRUS MAGNET OS?
but yes, XP needs to be setup to run all keyboards
but XP is now dead now at HP for 3 long hears and at Microsoft dead for 3 long years , so how can one get language packs when dead.
google is your only chance, and do know that doing that
you will get infected.
why not upgrade to VISTA.
this old PC is 2002 made, its 15 years old and not supported now.
we have 8 year newer ones sold for $20 used, in many used PC stores, even one with Window7 on it.
why not upgrade to a w7 old pc.
good luck finding any XP support now.
id avoid that like the Plague,
XP is DEAD,
let it die now, it needs to badly.
XP does not support all keyboards, a fact.
the install only supports 38 languages
vista is now dead, but 10x more safe.
load VISTA and dump XP.
the more new the OS, the more likely your old 15 year old chips are no supported, like for sure in windows 10. this old.
HP offers nothing,
below is risky but , there are few choices now.
https://restore.solutions/en/hpcompaqevon800/
Mar 28, 2017 | Compaq Keyboard
The@sign
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Oct 24, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
