Question about Refrigerators
Freezer works fine but fridge on bottom is warm, stuff used to freeze on the top shelf of the fridge and i would leave the fridge setting on between 2 and 3 and all was good but now i have consistantly been cranking up the fridge to the colder setting and its staying warm in the fridge while the freezer still works fine I did clean off a very small amount of frost in the back of the inside of the freezer and change the freezer setting from high to medium, this fridge is approximatly 12 yr old
  • 75 Answers
Fan circulateing cool air is not working ,need to be changed.call a mechanic cos only he can replace it.
Posted on Aug 24, 2010
My daewoo fridge freezer is freezing food I the fridge on every shelf
Turn down the cold control there can be 1 or 2 if 2 one is main electronic the other just a baffle that controls how much cold air in freezer is allowed into fridge that is be pushed by the fan located in freezer. Cold is only made in freezer then does a circular tour as it leaves cold in freezer moves top 2 bottom then as its warmed it enters freezer to do it all over again . Adjust baffle and or control in this unit it may show 0 or off but there seems to be a lot of movement available before it does turn fridge off. Ive had on a few occasions had how the shelf's are arranged deflect the or mess with the cold airs intended route.
Mar 16, 2017 | Daewoo Refrigerators
Refrigerator side too cold
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 28, 2011 | Cars & Trucks
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top of the freezer not freezing
SealedSystem problem. You need a "Certified Technician".
Apr 26, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
