Follow the procedure below to download your pictures from your phone to your computer.
1.Plug one end of the USB adapter into the phone, and the
other end into an available USB port of your computer. Look to the
bottom right of the screen and you should see an "Installing Driver..."
window pop up. Wait a few minutes to allow the computer to look for a
driver for your phone
2.Look for a window to pop up that tells you "Driver
was successfully installed." If it never comes up, or instead a window
pops up that says "Driver was not successfully installed," it means
your computer did not recognize your cell phone. In this case, you'll
need to look for the driver. If it did install, skip ahead to Step 5.
3.Install the driver by double-clicking on it.
Before you do this, make sure your cell phone is unplugged. After
you've installed the driver, plug in the cell phone, and it should be
recognized
4.Go to "My
Computer." Look for a new drive that has either the brand/model of the
cell phone in the name, or simply a picture of the cell phone on the
drive. It will probably have the drive name F:, I: or G:. Double-click
on it.
5.Go to Start > File > Settings >
Folder Options and select to enable hidden files and folders to be
shown. Then go back to your cell phone's folder and look around. You
should see a folder with the name "Pictures," "Photos," "images" or a
similar name. Double-click on it, and you should see all your cell
phone images.
6.Select images and right-click
"Copy." Then go to your desktop and create a new folder by
right-clicking and selecting "New Folder." Open up this new folder,
right-click and select "Paste." Your images will then be copied from
the cell phone to your computer where you'll be able to access them any
time.
Take care.
