Plantronics 220 blue tooth
Another bang bang solution...
Be sure to charge your headset for atleast 15-25 minutes minimum to get a starting charge. This will also give you 15-30 minutes of talk time to test out your headset and placement, and also get used to being a part of the bluetooth generation.
Once charged, press the call button(the big button on the side) and hold it down until you see a flashing red/blue combination of lights, now you only have 2 minutes to set this up, or you have to start over.
Once the lights are flashing on the headset, it is searching for a phone, now you go to your phone, and find your options for connectivity or bluetooth, once in your menu, look for the option to search or connect to a blue tooth device. Let it search/connect automatically.
Once it is connected, the flashing lights on your headset should stop, finish the connect process on your phone, if it says found it, install it, entering device data, etc etc, follow everything it says by entering YES, hitting OK, or CONTINUE.
Once it says CODE or PASSWORD to enter for your bluetooth device, enter 0000 .Which is ZERO ZERO ZERO ZERO and then press enter.
It should take 2-10 seconds for the password to initiate, record into your phone, and pair your device. This is a detailed explanation. Please rate me for my effort.
ManOwar
