My B&D 8210 cordless beater Type 1 3.6V dc does not charge , how do I get new batteries?
    Sergeant:
  • 264 Answers
You may get it from the store or bestbuy.
Also you may try a powercycle. It may fix the issue itself if the battery is not dead
Posted on May 05, 2008
  • Sameer Kashyap May 05, 2008
    Also check the website below.
    Click here
    The Power cycle that i mentioned is a in which you need to turn
    off the Palm. Remove the power sources like Battery and the power adapter(Its a step, you wont see anything happening). Than press and hold the power button for 20 seconds. Put
    battery and the Adapter back and turn on. See if it starts charging.
    Hope this solves your issue.
    Genius:
  • 1,142 Answers
Please provide the make and the model #
Hoover linx
How old is your battery? and did you keep it on charge when it was not in use?
Most rechargeable batteries require a spindown, where as you completely discharge the battery before recharging it again.
I know you aren't wanting to hear this but in all probability that battery is spent and will need to be reconditioned at a battery place, however, it will cost almost as much as a new one it would be your call.
if you have a ohm/volt meter it might be possible to look at the charger and get a volt/amp reading and then test it see if it is putting out the proper voltage it could be putting out a trickle charge and it would take forever to charge it.
there is one other situation to look at and if the beater brush or motor is causing a resistance it will pull a battery down quick.
I do not own this vaccum so I can only guess as to the possibilities.
Jul 02, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
I have a black & decker pivot plus that will not charge. How do I know if I need a battery or if I need a charger?
Batteries are only good for about a year, if they are older than that, take them back to the store and see if they are guaranteed at all, (all Ryobi tools and batteries have a date code on them, and they are all guaranteed for 2 years, a little plug for Ryobi,) that is all I buy now days, they work great. So, to check your charger, you will need a volt meter set on 12 or 20 v dc, and see if the charger is putting out, if not, then, the cost of a new ryobi might be the same as the fix for the black and decker. That is if you use the thing, we use our cordless tools every day and charge them every night, hope this helps.
Jun 28, 2011 | Black & Decker Pivot Plus Cordless...
I have an 18V cordless drill/driver. When I tried to recharged the battery, the battery stayed dead. The red light was on while recharging. The charger stand has red and green LED indicators but only the...
Chargers will out last batteries by a long time.You will need to get a new battery. Black & Decker is a cheap household brand and does not hold up for long periods of time. I have better brands and buy several new batteries every year.
May 30, 2011 | Black & Decker 18V Cordless Drill/Driver
WAHT KIND OF Battery DOES This Product have ? For Example LEAD-ACID&...
After opening the unit up, this info I found out about the rechargeable battery.
[Info off the battery's label]:
*GS Rechargeable Lead-acid Battery (Portalac) PE12V7A (12v 7Ah) - sealed lead battery*
I hope that info help you, or someone, if you got a 12v 7AMP tip positive DC wall adapter, that thearadacly(sp?) will charge the battery, but I'm doing guess work since I don't know much about the AMP in voltage stuff.
I tried my best.
Sep 22, 2010 | Campbell Hausfeld CC2300 Cordless 230 PSI...
Hellow Dear, My acer aspire 4935 laptop is not charging when plugged in & power button flushes along with charging LED near touchpad.Sometimes The horizontal led that lights when plugged in disappears...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 15, 2010 | Computers & Internet
Replace AC charger for Campbell Hausfeld CC2300 Cordless Compress
I tried my best.
Jun 28, 2010 | Campbell Hausfeld CC2300 Cordless 230 PSI...
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Nov 10, 2009 | Bosch Drills
Low battery won't charge,change battery,now dead won't charge????
I had the same problem so I got a new battery & separate charger to charge both new & old, then replace as required.
Nov 05, 2017 | Uniden Cordless Phone exai398i
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
