Question about Sony Network Walkman NW-E005 MP3 Player
When plug in windows does not recognize usb used to work ok
  • 4 Answers
What did you do before this problem started?
I am assuming that you have tried a different USB port, if that doesnt work a different computer?
Posted on Aug 28, 2010
  • daggeydo Aug 30, 2010
    found the problem only use genuine sony leads tried some cheapys thats was problem thanks
Driver download
If your computer does not recognize the USB device, first try method 1 to work around this issue. Method 1: Initiate recognition of the USB device by using Device Manager To initiate recognition of the USB device by using Device Manager, follow these steps: Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens. Click to select your computer as the location for the scan. On the Action menu, click Scan for hardware changes. Windows XP recognizes the new device. Close the Device Manager window. If this method resolves the issue, you are finished. If this method does not resolve the issue, go to method 2. Method 2: Disable power management of the USB hub Note If you perform the following procedure, you may also reduce the battery life on a portable computer. Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps: Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens. Expand Universal Serial Bus controllers. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed. Click the Power Management tab. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK. Repeat steps 3 through 6 for each USB Root Hub in the list. On the Action menu, click Scan for hardware changes. Windows XP recognizes the new device. Close the Device Manager window. If this method does not resolve the issue, go to method 3. Method 3: Restart the computer To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device. If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus Back to the top ' Give Feedback
Nov 11, 2013 | Targus AMW05US Mouse
Some USB that are attach to my pc are not recognized.
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
  4. Close the Device Manager window.
If this method does not resolve the issue, go to method 2. uparrow.gifBack to the top Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.
If this method does not resolve the issue, go to method 3. uparrow.gifBack to the top Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
Aug 14, 2011 | Computers & Internet
I have lg ms690 mobile device. When I attach the usb to my laptop, I get the message - one of your USB devices is malfunctioned and windows does not recognize it. I downloaded an updated version and still...
Ok I experienced this problem before..try to plugged your phone to the other usb port of your laptop try it at the back the power of the usb port there is sufficient to make your device to function properly..I tell you this because some of the usb port except from the back of a pc CPU gives insufficient power to a usb device that can make the usb that was plugged in it not work properly and not recognized by windows.
Jul 04, 2011 | Computers & Internet
My external hard drive does not appear in the my computer. i cannot open it and retrieve my file. it is recognized by the usb port but otherwise it is not accesible. i tried connecting it to other computer...
Hi Kuting_Jod, try to look out for a manual and a driver CD in theoriginal package for instructions - how to get your computer to recognizemy hard drive.
I hope i helped!
Jun 08, 2011 | PQI 500GB High Speed External H560 Ultra...
Gateway 310 s won't recognize a cd
Uninstall all the usb controller from USB controller
and now restart the computer.
If this method does not resolve the issue, go to method 4 .
Hope this helps.
Jan 14, 2011 | Gateway 310 S PC Desktop
Hi Running WIN XP (32bit) Have just replaced the Motherboard with an ASUS P5E3 Upon boot up, Windows XP dooes not recognise the USB mouse. The mouse is plugged directly into the MoBO's USB port. I...
Method 1: Initiate recognition of the USB device by using Device Manager----To initiate recognition of the USB device by using Device Manager, follow these steps:---
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Managerwindow opens.
If this method does not resolve the issue, go to method 2. Method 2: Disable power management of the USB hub---Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:===
  8. Close the Device Manager window.--
If this method does not resolve the issue, go to method 3--- Method 3: Restart the computer---To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site:---- http://support.microsoft.com/contactus
--- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 02, 2010 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
USB Memory Key not Recognized on Desktop running Windows Vista
check the formats of the keys. if they are NTFS they might not be recognized by earlier Windows versions. What version of windows does the laptop computer use? It may be as simple as using the correct formatting (FAT or FAT32) on the USB memory key.
Sep 14, 2009 | Maxtor Hard Drive
Windows does not recognize USB connection to the SpeedStream 6520- malfanctioning
try using different USB port. if the it is unknown device. means the machine didn't recognized the device. you may have to install the device driver. (windows is a funny thing).
Nov 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Says camera is not connected to computer
I'm assuming that you are using a Windows based machine? If so, try another computer. If the camera is recognized when you plug it in, you have a software / driver issue and it's not in the camera. Just plug the computer into any other computer and don't bother with the software.
Oct 05, 2007 | Nikon Coolpix S1 Digital Camera
Sony Network Walkman NW-E005 MP3 Player Logo
41 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
