Question about Dometic RM2620 Refrigerator
I have a dometic RM660 gas fridge. The gas lights but it doesn't cool down. You can also hear a sound coning from the back that sounds like water trickling down a pipe. There isnt and obvious leaks. Would it be worth fixing or can i diagnose the problem easily myself.Thanks, Dave.
    Top Expert:
  • Dometic Master
  • 5,677 Answers
Bad cooling unit replace
Posted on Oct 06, 2017
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
VtToolMan
  • 704 Answers
SOURCE: Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Posted on Jul 30, 2009
motor1258
  • 6674 Answers
SOURCE: my dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
Posted on Jun 03, 2010
Clicking sound not real cold
see if plugged in at back and voltage to it
Apr 16, 2014 | Dometic RM2652 Refrigerator
Dometic Americana RM2852 refrigerator does not work. Has power to it, light inside works and lights at top indicating 'AUTO' mode are illuminated, but refrig doesn't work in any mode. Gas is...
Have the same unit but experience no problems. Sounds like a freon leak has left it inert. You can of course switch from auto to gas and eliminate the auto switch over as part of the problem. You can see the gas flame in the outside access hatch, (or maybe hear it) to be sure it is getting gas. since it doesn't respond in auto, which would also work in electric mode, I think it is the freon problem.
May 11, 2011 | Dometic RM2852 Refrigerator
New season start up probnlems.
Have you given it 24-48 hrs to cool? Coils at rear will start to get hot at top, and slowly work there way down.
Yes, 24-48 hrs upside down, then same right side up before turning on, has been known to buy you some time.
May 20, 2010 | Dometic RM2652 Refrigerator
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic RM 2800 Refrigerator will not cool. freezer is some cool. this is on LP gas
Jul 12, 2009 | Dometic Refrigerators
Dometic rm 2607 makes a gurgling sound when started in a/c or lpg . no cooling, in fact the inside of fridge heats up.help ? thanks
If your cooling unit is gurgling, then you have air in the system or a bad cooling unit. There is a process known as "burping" that should help repair this. It is a rather lengthy process and will require two people.
1. Access the rear of the refrigerator. Turn off the LP gas to the unit. Remove the LP Gas line and the 12Volt supply. Unplug the fridge.
2. Remove the screws in the rear at the bottom and then remove the screws from the inside.
3. Pull the fridge out and lay it down on it's right side for 8 hours.
4. Flip the fridge on it's top for 8 hours
5. Now the left side, then back to normal.
6. Reinstall the fridge and turn gas back on.
Hope this helps,
Jeff
Jul 08, 2009 | Dometic CS-200 Wine Cooler
I have a Dometic RV fridge that wont get cold. It is a model RM 2401. It easily lights on gas, the coils get hot and it makes a little gurgling noise but does not get cold. Can this be recharged?
Jun 29, 2009 | Dometic RM2620 Refrigerator
Dometic problem
May 11, 2008 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2620 Refrigerator Logo
289 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
