Dear Sir, We bought a Westpoint fully automatic washing machine (Model FE 2) in 1997, which has been working satisfactorily for last 12 years. Recently it developed some problem in timer, and after spinning cycle, it was not stopping, we used to stop manually. I personally opened the timer, one plastic tooth was broken, some how managed to file a tooth. Now the timer is OK. But unfortunately I interchanged the wires (though I had marked them correctly) in the timer, so the drum is rotating in one direction in slow speed, no other option is possible due to wrong wiring. I sincerely request you, if you can provide me the wiring diagram of the timer, I can fix this and still be proud of using the machine for some more time. I strongly believe your customer satisfaction, and hope to get a solution for my problem. I salute your team for providing me a machine, which is still strong after working for last 12 years. Regards, Sushanta Samal
SOURCE: Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Posted on Sep 24, 2008
mohammed387
  • 1952 Answers
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity. Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd and tends to collect lint. Run a coat hanger up the hose and see if you can fish something out also check that belt.
Posted on Oct 06, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
SOURCE: Bra wire trapped in drain of washing machine noisy when drum rotates.How can I get it out?
Fishing line was looped through the larger holes in the back of the drum with a lassoo on the end of it & hooked round the wire then drawn out. A very time-consuming procedure in a confined space with a fine bendy light to illuminate the part.
Posted on Jun 11, 2009
SOURCE: Washing machine is not completing spin cycle at
The washer runs but does not spin...
Posted on Jun 10, 2010
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL engrabih12@hotmail.com
Apr 13, 2011 | Samsung SW62ASP Top Load Washer
My westpoint machine model WMC-5260 SERIES DOES NOT WORK WELL. IT IS AS IF THE TEHRMOSTAT HAS FAULT. where can i find a maintainance engr in nigeria?
Sorry. I doubt anyone on this forum could give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in telephone directories OR stay on line and search for 'westpoint washer service' for instance or 'westpoint washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
Good luck,
John C
Mar 04, 2011 | Washing Machines
I have got a westpoint washing machine XQG50-604 the water switch is faulty but the machine is working it doenst pour water on the machine at all.rose e-mail:rntuli@uj.ac.za
Hi
I have a Westpoint front loader washing machine, model number XQG50-604. The power button got stuck, opened machine up and find the power switch burnt out. Where is Johannesburg in South Africa can I get a new switch please? Also can you advise how to remove old switch and to replace the new switch.
Regards
Juanita
Feb 15, 2011 | Washing Machines
Dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Dec 08, 2010 | Samsung Washing Machines
I want the manual of WESTPOINT WMB-50T
I have big problem my washig machine is a top loading Westpoint brand, model : wtw-700 its drain well but can't spin at all please help .
Sep 30, 2010 | Washing Machines
We have a Whirlpool 7 KG fully Automatic washing and the display is showing FE and the water is not filling in the Machine
either your water supply is shut off or the water fill solenoid valve isnt working to let water past the fill valve or the solenoids are not getting power from the control unit to do so
Sep 29, 2010 | Whirlpool Washing Machines
How to operate a whirlpool fl 5053 washing machine
Dear Sir,
How to operate fl5053-500 model whirlpool washing m/c (fully automatic),
pls forwad manual for mail id.
this is my mail id = rajan_raman@yahoo.com,
solution = a picture or video is helpful for as,
pls reply me on further information by mail.
thanks & regards ,
raman.
Nov 14, 2009 | Whirlpool Washing Machines
We have a westpoint wkw1225tl and the program
once machine fills with water a pressure switch activates to say stop filling now wash/ the motor should then start and heaters operate with the timer decreasing dont know your model too well but hope this helps you....
Nov 05, 2009 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
