Dishwashers Logo
Posted on Aug 24, 2010
CODE ERROR : 4 ARISTON DISHWASHER LST 329 - Dishwashers
I have an Ariston dishwasher and its giving me a F15 error code... What does that mean?
This error message indicates that an anti-flooding overflow is taking place. This may be related to a failing rubber gasket around the dishwasher door, a defective water inlet valve, or a faulty float switch or sensor. The float and switch sensor is activated by pressure and if faulty will need to be replaced.Dec. 21, 2020
Ariston Dishwasher F15 Error and Troubleshooting ' Mix Repairs
Oct 22, 2021 • Dishwashers
2answers
Ariston dishwasher flashing code a13
http://salvationarmynaples.net/readpdf/ariston-dishwasher-manual-l64.pdf
http://manualslibrary.net/ARISTON-DISHWASHER-MANUAL-OPERATION.html
These are the sites for two manuals on your machine. They are free downloads that can be read by any computer. I'm sure there is a code list in there somewhere.
Dec 10, 2016 • Dishwashers
Ariston dishwasher lkf 720 has a problem on/off, washing and end indicator lights are flashing
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes: the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
After you determine which the alarm code appeared we will able specifically to help you.
Dado
2answers
Why Ariston lbf 51 lights flash rapidly
24501406-0h3kxpflbez5mdeb5anq3st4-3-0.jpg If flashing any of the 4 LEDs (see picture) means that the dishwasher discovered a malfunction. Depending which combination of LED flashes (one LED, two LEDs, three LEDs or all four LEDs) indicates the specific error code.
Dado
3helpful
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 • Dishwashers
Ariston LL64 error
call 1800 815 589 ariston australia
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
