Question about Dell Latitude C640 Notebook
Usb ports is there any way to replace some of the excess ports on the back of my laptop that i don't use with usb ports?
  • ljezisek212 May 05, 2008
    my laptop is a dell lattitude c640
Yes, but I would not recommend it as you would be soldering wires to your motherboard and run the risk of frying it in the process.
Not to mention you need to desolder the other ports first.
Posted on May 05, 2008
LG laptop usb ports not working
do you have the program needed to get what you have on your flash drive? If you don't have a photo program or pdf program or what ever to open it, it won't work. try connecting something else that uses USB port to it and see if that works, then you will know if its a program problem or your computer. if its the computer, you can replace it.
May 07, 2012 | Computers & Internet
WHERE DOES MY STICK GO IN AN IBM THINKPAD LAPTOP
The model number is located either on the bottom of the right corner of the screen and on the label on the bottom of the laptop and the location and number of USB ports vary with different models.
The USB port is a connector/port that is 12x5 mm in size, some model thinkpad have onlt one USB port and some have 2 USB ports.
The USB ports are usually located at the back or at the sides of the laptop.
The T30 model has 2 USB ports at the back of the laptop located between the LAN and PS2 connectors.
The T40 model has 2 USB ports located at the left side of the laptop.
The A31p model has 2 USB ports located at the back left hand corner of the laptop.
The R32 model has 2 USB ports, one is located at the back left hand corner and the other is located on the left hand side of the laptop.
Feb 08, 2012 | IBM Computers & Internet
I PLUGGED MY MP3 PLAYER INTO MY LAPTOP USB PORT AND IT USED TO WORK NOW IT SAID THE USB DEVICE HAS EXCEEDED ITS POWER LIMITS OF ITS HUB PORT AND WONT WORK NOW
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Sep 05, 2011 | Computers & Internet
DEll 1720 vostro laptop running xp sp3 has recurrent and progressively worse "a network cable is unplugged" problems on LAN
This is mostly likely either
a) faulty cable
b) faulty network point
c) excessive 'wear' on the laptop's network port
Check a & b as these are the easiest options to fix. If its c) then you can try (carefully) cleaning port contacts with a suitable 100% pure isopropyl alcohol (turn laptop off first). Failing that, then if the laptop is in warranty then I would contact the warranty provider (presumably dell) otherwise the easiest /cheapest option would be to purchase a USB RJ45 network port which you can by in most good computer/electronic shops
Please take the time to rate this answer. Many Thanks Don.
A USB device has exceeded the power limits of its hub port
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Mar 11, 2011 | HP Compaq nx6110 PC Laptop
Is there a USB switch like a KVM switch? Where do I go for the best price on such an item?
All you need is a USB hub, I suggest you get a powered type because if any USB device you connect into this USB hub that draws excess power from the laptop, you will get an error power message. A powered USB hub does not rely on power from the laptop's USB port.
These USB hubs allow you to connect several USB devices at once. Most USB hubs have 4 USB ports.
Jan 28, 2010 | Lenovo ThinkPad X301 Notebook
Connection to laptop
Most printers are connected to laptops via the USB ports. If the printer is supposed to be wireless, then you may have to connect the laptop via the USB port so you can activate the wireless port.
Don
Nov 23, 2009 | Canon Pixma iP2600 Photo InkJet Printer
My remote don,t work on my acer 1800 , and the sd card reader don,t read. I did replace the battery in the remote,I have XP MEDIA CENTRE installed on the laptop.
laptops don't have remotes, and for the sd card reader unplug it from the laptop and try it in a different usb port if that does not work then i dont know. ive got an sd card reader and my laptop didn't find mine until i tried it in a different usb port
Oct 27, 2009 | Acer Aspire 1800 Notebook
Power Surge on Hub Port
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Dell Latitude C640 Notebook Logo
Alun Cox
