Question about Troy Garden
Need to replace pull rope - Troy Garden
  • 2strokeguy
    2strokeguy Aug 24, 2010
    What are we working on?
  • rickw1953 Aug 24, 2010
    I have a Troybilt TB90BC trimmer/ brushcutter the pull rope broke . It looks like the clutch assembly needs to be removed so I can get to the flywheel but I can't tell how to remove it !
  • 183 Answers
You will need to lock down the cylinder to remove the clutch. This is not an easy repair. Remove the spark plug and lower the piston. Take a piece of small rope (the broken one works fine) and fill the cylinder with the rope. Raise the piston to "lock the cylinder. The clutch drum can now be removed by inserting a T15 or T20 torx into the center and turn the screw counter-clockwise. Then take a pair of large slip-joint pliers and turn the clutch assembly counter-clockwise to remove. Make note of what order all the little washers come off. Also, make sure to remove the clutch as an assembly...it is very difficult to put back together. When reinstalling the clutch, it is VERY important to get it tight. Failure to get the clutch tight will result in major engine damage.
Make sure you replace the rope with 40" of #3.5 braided rope. Melt the ends of the rope so it doesn't fray and use a figure 8 knot to secure.
Posted on Aug 27, 2010
Testimonial: "Thanks it work perfectly . I scatch my head on this for a couple day's !"
How do I replace the pull cord on snapper sr1330 riding mower
remove coil cap look at the rope pulley pull old rope forward till you get to end knot hold pully pull not out with the rest of the rope then wind pulley up till it wont go any farther back off one turn alighning the cover hole with pully hole use ascrew driver stuck between the slot on cover and pulley ten get your rope take a lighter and burn the end of the rope the take a rag pul the end of burt end of the rope shuold leave a pointed rope then take rope and stick through pully hole then the housing make the rope about 70 iches long it will be to long i no but just do it tie a knot in tend on the back of pully take lighter and heat it still it melts a very little the knot that is pull rope on through pulley hold rope remove screw driver slowly let rope wind up on pulley still it stops you will have rope sticking out reistall pulley cap then put handle on rope put handle all the way down to cap pull rope one turn push handel down to cap atie a knot in rope as close to to handel as possible heat not like the other end cut rope with 1/2 inch of rope sticking out of knot
Sep 13, 2014 | Snapper Garden
How do you take the outer shell off the engine of my Poulan 446 T pole saw/weedeater. I need to replace the pull cord. Also, how to properly install a new pull cord. Thank you. Don
I do not have knolage of how to take off the cover but I have replaced start cords on other saws. There is a hole in the pully you put the rope through and then tie a knot it it so it won't pull out.Usually there is a half circle in the edge of the pulley you place the rope in so you can wind up the spring but not take up the rope. You will need to count the turns the pulley makes when the rope is pulled out then add one or two more turns so the rope is pulled in snug. Then you take the rope out of the notch and let it coil up nomally.
Aug 03, 2013 | Garden
The pull cord broke I just can figure out how to
1) Remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope.
This is the area that causes so many guys a lot of extra trouble!
2) Locate the string that is left and the hole it is threaded thru
3) Determine how much string has broken off of the rope that came out
*Note: if more than 1 inch is left, then the rope needs to be replaced
4) Obtained a length of rope appropriate for your engine, it is always better to have too much rope.
You can always shorten if it is too long.
Make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) Wind the rotor in the direction of what the rope would pull,
(this will tighten the spring) until the spring is completely wound.
Remove 1/2 to 1 revolution.
6) Install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
Tie a knot in the end of the rope, leaving a 3/8" tail free.
Then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
9) When the unit is functioning proplerly, re-install housing onto engine.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
The starting cord has broken and I need to make repairs . I would like some guidence
Take the housing off for the pull rope. Inside you'll find a spool. Take that off and underneath you'll find a spring. Replace the pull rope and connect it to the spool like the old one is. With the handle outside of the case run the rope through the pull rope hole then attach it to the spool. Wind all but a foot or so of the new rope back onto the spool. The spring will have a way of attaching to the case and to the spool. Attach the springs to the case. There will be a notch cut into one side of the spool. You need to lay the rope into this notch and then place spool back into the case at the same time attaching the spring to the spool. Don't worry about tensioning the springs. Once the spool is back in you need to start winding up the spool in the direction that tightens the spring. You'll need to make about 5-8 rotations depending on the length of the rope. At this point, position the notch in the spool even with the hole where the pull rope enters the case. Pull on the pull rope handle until you pull the slack rope back through the notch and outside the housing. Then release the rope and the slack should be pulled back inside the housing and wrapped around the spool. Here is a video on changing a pull rope on a lawn mower. The idea is basically the same.
http://www.youtube.com/watch?v=i3ZMVFi0yqY
Nov 27, 2009 | Ryobi Garden
Renew pull start cord
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Nov 24, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
The rope doesn't pull smoothly. I removed the
Before installing fasteners for the recoil to the housing, pull the rope a small amount 2-4". With a small pressure from your other hand, at the same time push gently down on the recoil housing. This should partially rotate the flywheel and align the pawls to the rope rotor. Repeat this proceedure until you feel the pawls drop into place.
You may want to review the proceedure for installing a rope to complete your repair.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Nov 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Broken pull starter rope
remove pulley that rope goes on, wind it with new rope, wrap it till it is full, then feed rope thru hole in housing, put pulley back in place, put rope thru pull handle, pull thru till you feel spring catch tie a knot and that should do it......be careful when removing pulley not to dislodge recoil spring
Oct 22, 2009 | Garden
Pull rope does not return
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Sep 03, 2009 | Garden
Replace pull cord Big Wheeled weed EaterString
First, remove the recoil assembly but dont disassemble!
You'll need about 3 1/2 ft. of the same size rope. Tie a knot into one end of the rope. While holding the pulley in place observe the direction the pulley moves when rope is pulled. Release pulley and cut and remove old rope. Continue winding pulley in direction rope would pull it. Do no wind too tight. Line up holes in recoil housing and pulley then push rope through pulley and out housing. Tie on handle and install recall in reverse order.
Jul 02, 2009 | Garden
Garden Logo
88 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
