Question about Sony VPLES1 Projector
Hi My Sony VPL ES5 SWITCHES OFF THE LAMP AFTER 2 MINUTE
Hi your projector probaly has done around 2122 hrs on the bulb just reset the lamp timer and you should be good to go ps this worked for me (answer yes to replace bulb and clean filter then press ok pps might be a good idea to start saving up for a replacement bulb hope this helps cheers !!!
Posted on Feb 22, 2011
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
Green light is continuesly bling but the projector is not given the display
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Dec 11, 2014 | Sony VPL-BW5, VPL-ES5, VPL-EW5, VPL-EX5,...
How do I fix Lamp/Cover flashing light?
There is a switch or a button that gets depressed when you close the lid of the lamp compartment. See if the plastic of the lid is broken or not hitting it right. Not screwed down right or the lamp is not seated all the way down.
Dec 20, 2012 | Sony Office Equipment & Supplies
Sony projector vpl ex5 yellow display problem
try replacing the bul/lamp.
warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
May 21, 2011 | Sony VPL-EX5 Projector
How to reset lamp counter in Sony-VPL-ES3
To reset lamp timer in Sony VPL-ES3,
Press following keys on the remote control in following order for less than 5 seconds each,
RESET, <<, >>, ENTER
This will reset lamp timer.
Nov 26, 2009 | Sony VPL-ES3 Multimedia Projector
When the SONY VPL - ES1 projector is turned, the lamp cover opens , no light and after a while lamp cover closes. Mounted on the ceiling, it has happened after it was working well previously. Lamp has...
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Jun 11, 2009 | Sony VPL-ES1 Multimedia Projector
VPL-EX1 Just bought it from someone the lamp is 450 hours, it worked fine with no message. no im trying to turn it on and it will just lift itself and lamp cover moves but then nothing happens and after a...
I have had the same problem with 3 Sony VPL-EX1s and Sony will not answer emails regarding the problem. Hence I wont be purchasing Sony projectors again.
Apr 01, 2009 | Sony VPL-EX1 Multimedia Projector
Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Feb 21, 2009 | Sony VPL CS5 Multimedia Projector
SONY VPL-CS3
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
Sony VPL CS5 Multimedia Projector Problem
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Oct 17, 2007 | Sony VPL CS5 Multimedia Projector
Sony VPLES1 Projector Logo
445 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
