Question about Liquid Video MVOHD80 Car DVD Player
2008 Dodge Avenger, DVD shuts off when car goes in drive
Is there anyway to bypass this feature so that the movie will stay on while drving?
thanks
  • 3 Answers
Some one has connected your DVD player to the wrong hot wire. The best way to resolve this problem is to connect the DVD player to the very hot wire that your radio is connected to.
Posted on Dec 16, 2008
2008 Dodge Avenger window will not stay up
Sound like the "auto-pinch" sensor in the motor/drive assembly has become too sensetive
Mar 05, 2014 | 2008 Dodge Avenger
Where is the Location of a/c compressor clutch relay on 2008 dodge avenger
The compressor magnetic clutch is located and attached to the front of the AC compressor and the engine drive belt goes over it
Oct 03, 2013 | 2010 Dodge Avenger
2008 Dodge Avenger DVD shuts off when car goes in drive
car desined to but go to a radio outlet as im sure you can have it programedto its illegal in uk whilst driving
Aug 16, 2012 | Car Audio & Video
2008 Dodge Avenger Airbag light stays on
i got a 2011 dodge avenger the airbag warning light stay on , can u someone give me an idea how to fix it please?
Dec 13, 2011 | 2008 Dodge Avenger
How do you shut change oil display after changing oil on dodge avenger
turn key to on position but don't start, then pump gas pedal slowly 3 times and light should go off and stay off just did it on my 08 avenger
Mar 18, 2010 | 2008 Dodge Avenger
UCONNECT Activation problem for 2008 Avenger R/T
I also have this same problem, I installed the bluetooth module and the ipod integration kit. I have the same head unit. Did you find an answer on this? if so let me know what you found out. thanks
djc1979@nycap.rr.com
Feb 20, 2010 | 2008 Dodge Avenger
2008 Dodge Avenger electrical problem
i also have a 2008 avenger rt.its o good thing your car is under warranty it is must likely the turn multifunction switch.which controls a lot of stuff light turn signals brights. i hope this helped please rate this answer thanks.
Feb 01, 2009 | 2008 Dodge Avenger
2008 Dodge Avenger SE oil pressure light?
Don't worry about the oil pressure light, they key was on, the engine was running and suddenly stalled, the system saw it as low oil pressure on a running engine situation and warned U, it is not the cause of the stall, the stall is most likely related to the following.
Here is the most common cause of surges and stalls and low idle, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Dec 16, 2008 | 2008 Dodge Avenger
Sirus dvd player in 2008 dodge durango Limited
its illegal to have a dvd screen playing where the driver can see it when they're driving. thats why it turns off when you put it in drive. it can but changed by switching some wires around but you can get a ticket for it if cops see it.
Dec 29, 2007 | Car Audio & Video
Bypassing the brake wire so i can watch video whenever i want
Hello haehner, Question why would you want to watch a movie while driving? That beeing said this is a tech forum so here goes. Take the brake wire attach it to a switch, take the other endof the switch and attach it to ground. In most cases companies have gotten wise to just grounding the break wire, so they have made it so the feature must be keyed off the break pedal light switch and must be connected, if conected to permanent ground it senses this and shut the unit down anyway, so what you have to do is connect the switch as I told you and try the sequence of on-off-on and this will disable the break feature. Again, don't do this the break wire is a safety feature. Thank you, Shuttle83
Sep 06, 2007 | Pioneer AVH-5700DVD DVD AV HEADUNIT...
Liquid Video MVOHD80 Car DVD Player Logo
608 people viewed this question
Top Liquid Video Car Audio & Video Experts
xxxxxx xxx
Are you a Liquid Video Car Audio and Video Expert? Answer questions, earn points and help others
