Control panel touch screen of Photocopier RICHO MP 3500 not functioning on touching the points by fingers?
  • 903 Answers
Many of the Ricoh MP3500's and similar models are having this problem. Ricoh has since changed vendors for those touch screens, but if you have a service contract or warranty on the copier you can probably get it replaced for free. Contact your local dealer, or if you don't have a service contract you can contact Ricoh directly and see what options they offer.
Posted on Aug 24, 2010
How to enable the touch screen function
Try this:
  1. Click Start and then Control Panel
  2. In Control Panel, click on the Pen and Touch icon
  3. In the Pen and Touch Settings window, click the Touch tab
  4. Check or uncheck the checkbox next to Use your finger as an input device
  5. Click Apply and then OK
Apr 24, 2015 | Computers & Internet
Where ih coil at copier richo mp c3500
remove the fuser. See the hole in the black plastic assembly behind the fuser? That is what you are looking for. The thermostat is blown. Put some super glue on your finger. Then touch the thermostat and tug. That black mesh pulling back out will reset it. To permanently fix it you need to replace it. A lot of disassembly but much cheaper than replacing it. So long as you know how to do it and where to get the part. Let me know if you need a part number. Otherwise, it will cost hundreds for a service tech to do it. They will only replace the assembly, not the thermostat.
Oct 01, 2014 | Ricoh Aficio Mpc 3500 Color Copier
TOUCH SCREEN
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Touch Panel Adjustment
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
10-Key Pad.
Functions • To adjust the position of the Touch Panel display
Use
Adjustment
Procedure
pen.
NOTE
Touch pad for sony vaio mp 5 player
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Sony Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 19, 2012 | Computers & Internet
Can you use your finger, or other item, other then the pin to use the touch screen on the Toshiba Portege 3500? If so how?
No you cannot. It does not have touch capabilities. But that should not be too difficult to verify. Poke your finger on an icon to see if it comes alive.
May 12, 2011 | Toshiba Portege 3500 Tablet PC
I have a Ricoh MP C2500 Copier and I can not select any functions on the menu when I press it with my finger
Your touch screen went bad. This is a common problem with many newer Ricoh models. Get in touch with your service technician to get a new screen.
May 26, 2010 | Ricoh Office Equipment & Supplies
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
May 07, 2010 | Dell Latitude D610 Notebook
How to change display from Japanese to English
4-2. User’s Choice Function Setting Procedure
<Setting Procedure>
1. Press the User Mode key on the control panel and then touch the “User’s Choice” key.
2. Select the page number key that contains the desired function from among 1/6 through 6/6 shown YOURS WOULD BE 1/6
at the bottom of the Touch Panel.
3. Select the function to be set and make settings as required.
4. After the settings are complete, touch the “Enter” key to validate the settings.
NOTE:
The function selected is highlighted.
<Exiting the Mode>
Perform any one of the following steps to go back to the Basic screen.
 Press the Panel Reset key on the control panel.
 Touch “Exit” on the Touch Panel.
Language Selection
English
Select the language of the Touch Panel messages.
French
Dutch Italian Spanish
Portuguese Danish Norwegian
Swedish Finnish Greek
–Metric Areas–
English German French
Japanese Chinese Portuguese
Mar 18, 2010 | Minolta Office Equipment & Supplies
Cracked touchscreen
There is no need to replace the whloe lcdscreen, you just need to replace the touch screen & panel which is a thin glasstop on the top of the lcdscreen. The whole lcdscreen is expensive, while a touch panel is much cheaper than that. And we could provide all kinds of PDA accessories. Here are some information for you In general, PDA LCD screen comprises the touch screen. LCD screen acts as a display of PDA or SmartPhone, and the likes, which cannot go without LCD screen. Touch screen is short for touch screen digitizer which seizes the upper part of PDA LCD screen. It is pressure-tactile, runs with gentle touch of stylus, finger and other tele-pointing function-possessed device. Different from LCD screen, the touch screen is an optional component for PDA, SmartPhone, and the likes. A PDA can function well even without the assembling of a touch screen for the availability of keyboard.
Sep 09, 2007 | T-Mobile MDA
290 people viewed this question
k24674
jasbo
jasbo
