Question about Microsoft Computers & Internet
I have P1865D7 mercury motherboard... I want to add a graphic card of 1 GB. Will it support 1 GB and what processor is this AGP or PCiExpress ??
    President:
  • 2,668 Answers
Brown slot=AGP White slot=PCiE. 1GB card should be OK
Posted on Aug 24, 2010
Testimonial: "I will check my hardware again, but didnt find any color specific slots... anyways lots of thanks for the suggestion."
What would be the best compatible 512 MB GPU(with shader 3 or 4) working with P4I45GV 3.00 /P4 2.4 GHZ/1 Gb ram ?
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
Any of them Shubham.
If we are to discern by a few known statements;
1) It is believed in some 'geek communities', that using the same manufacturer of motherboard chipset, and graphics chipset; to be a good thing.
For example an AMD motherboard chipset 'plays well' with an AMD ATI graphics chipset;
Nvidia motherboard chipset 'plays well' with Nvidia graphics chipset.
Intel motherboard chipset with Intel graphics..............no wait,....... there is no Intel graphics chipset, unless it is -> Integrated Graphics.
[ Intel GMA ]
(Integrated Graphics is also said as OnBoard graphics. ON the motherBOARD)
2) DOES NOT MATTER what graphics memory type is used.
Motherboard can use DDR Sdram ram memory, and graphics card can use GDDR5.
Why?
Because the graphics card has it's own Processor, and Ram Memory.
Graphics Processing Unit, or GPU; is the Processor,
http://en.wikipedia.org/wiki/GPU
Graphics memory is the ram memory.
Operates independent of the system resources.
The graphics expansion slot on the P4I45GV (P4 i 45GV), is an AGP slot.
Accelerated Graphics Port,
http://en.wikipedia.org/wiki/AGP
It will use an AGP 4X, or AGP 8X graphics card.
Use an AGP 8X.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=agp+graphics+card+512mb
REMEMBER;
1) ALWAYS follow Anti-Static Precautions.
2) INSTALL the software for the graphics card F-I-R-S-T,
(Drivers and 'control panel')
THEN unplug the computer from power, follow Anti-Static Precautions, and Physically plug the graphics card into the motherboard, and install.
3) L@@k at the system requirements (Minimum) for the graphics card.
Specifically the Power Supply requirements. You need a Power Supply with enough Wattage, to handle the graphics card.
[ Handles the graphics card, and -> Motherboard, Processor, Ram Memory, and peripherals; Internal and External.
{Harddrive/s, optical drive/s; Internal
Mouse, Keyboard, external harddrive, etc; External ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | Computers & Internet
I want to be know what is compatible with AOpen s651m motherboard. i'm kind of an ammature, so please help.
AOpen S651M motherboard:
1) Processor Support:
Uses Intel processors that fit in a Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
The Processor has the contact pins (478 of them), and the processor socket has the socket holes. (478)
The Maximum FSB supported for the processor is 533MHz.
(Front Side Bus, 533MegaHertz)
Processors supported;
http://en.wikipedia.org/wiki/List_of_pentium_4_processors#Northwood_.28130.C2.A0nm.29
Start with the Northwood Core models shown in the link above.
The ones that have a Front Side Bus of 533MT/s, and fit in a Socket 478.
The few shown in the next chart, Prescott (90nm), may not work. The voltage requirement.
2) Ram Memory Support:
DDR Sdram that operates at 333MegaHertz, or commonly known as PC2700.
TOTAL Maximum Amount is 2GB.
There are two ram memory slots. The Maximum Amount for EACH ram memory slot is 1GB.
If you only have one ram memory module ('Stick') place it in Slot 1. (DIMM 1)
This is the ram memory slot that is closest to the Processor.
[ The Processor 'sees' ram memory Slot 1 first ]
Graphics Card Support:
The graphics expansion slot on the motherboard is an AGP slot. (Advanced Graphics Port)
It uses the AGP 4X technology.
Above the 3 white PCI slots is the brown AGP slot.
Use AGP 4X/8X graphics cards.
(These types of AGP graphics cards can be used in an AGP 4X slot, or an AGP 8X slot)
Example of a AGP 4X/8X graphics card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814139053
Another one,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161318
,and yet another one,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161337
For additional questions, or to have me clarify anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Sep 24, 2011 | AOpen S651M (918EM10S50) Motherboard
Compatability
You have an AGP expansion slot for a graphics card.
(Accelerated Graphics Port)
It uses either 1x, 2X, or 4X graphics cards. Since the only AGP graphics cards out there are 4X or 8X, the 1X, and 2X are moot points. (They were also Junk anyway!)
Your AGP graphics slot only supports AGP graphics cards that are 1.5 volts. There are AGP graphics cards out there, that are Universal. Universal in that they will run as AGP 8X, (.8 volts), or AGP 4X, (1.5 volts)
This is an example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4103516&CatId=318
Don't expect to play the high end new intense games with this. I'm afraid you'll have to update your motherboard, processor, ram memory, and a better graphics card to do that.
(Example? XFX Nvidia nForce 680i LT SLI motherboard, Intel Core2 Duo E8200 cpu, Corsair XMS2 PC6400 ram memory, 1GB x2 of them, (DDR2 at 800MHz), and XFX Geforce 9800GTX+, vid card. (Plus OCZ SteathXStream 600W power supply)
This won't break the bank, and will slam some games to the wall!)
Jun 05, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Can i run ati radeon x1650 512 on asus k8N motherboard
Yes you can run the AGP version of the Radeon 1650 pro on your system. It is always best & recommended to upgrade memory in pairs. You could upgrade to `gb by purchasing a 1 gb kit which would be 512 x 2. That way you have a matching pair of RAM modules. As for a cpu upgrade you can go to the Asus website and see what cpu's are supported by your motherboard. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | ATI RADEON X1650 Graphic Card
Max hard disk support
hello. the motherboard supprts this
Max Supported RAM - 3gig
Audio Output - Sound Card • 5.1 Channels • Line Out
Video Interface - AGP 8x
On Board Graphic Processor - Intel Extreme Graphic
Expansion Slots - AGP x8 x 1 • PCI x 3 • CNR x 1
don't forgett to rate. Ty
Jan 09, 2009 | Mercury P4VM800M7 Motherboard
Will mercury mother board (pvm7pro 1.0) supports graphic card
first you must check that *********** board has capacity to use 8x graphic card, if you had a spare 2x or 4x graphic card try on it.
send me reply
Dec 01, 2008 | Computers & Internet
AGP graphic drivers update for Mercury Mainboard
http://ati.amd.com/support/driver.html
there u can find all drivers for all common operating systems
Dec 03, 2007 | ATI RADEON 9550 Graphic Card
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
