Question about Watches
How do i change the datewithout keep winding it
    President:
  • 2,501 Answers
Your watch sounds like a mechanical type (old).
Older watches rely on the hour hand passing 12 to re-set the date.
Wind your watch until the date changes and then turn the hands backwards passed 12 and then forwards again to advance the date again.
How far you need to wind it passed 12 (in both directions) is something that you will have to find out by
experiment.
Posted on Aug 24, 2010
  • Michael C. De Vito
    Michael C. De Vito Oct 01, 2010
    mcdevito75 here, Thank you David, you are absolutely correct. To change the date on the older Timex watches without going thru the entire 24 hour cycleis just as David the first solution suggested, Turn the hands until you see the date change, now turn the hands backwards until the time is 9:30, then forward agin to see the date change, repeat tis until the date is 1 day before the actuall date you need, now go thru the 24 cycle to get the correct date. With this your date will change as it should.
The Stuhrling classic cuvette works by the movement of your wrist or winding. It is difficult to find the right space to wind, change the date or time as they are all so close together. Does anyone have...
Just set the time and date and wear it, your movement should be enough to keep it running, or give it a good shake. Automatic watch winders are also available to buy
Sep 26, 2013 | Watches
The tissot visodate watch is automatic not battery driven.
I would not wind the watch manually. I also have a Tissot. If you cannot wear it often enough to keep it going, you can purchase a watch box that is made for self-winding watches which will turn the watch periodically in order to keep it wound.
Oct 19, 2012 | Tissot Visodate Automatic Leather Mens...
How to change the date on a fossil stella watch
For the single dial (winding crown). Pull out one click and this will change the date, pull out another click to change the time and keep winding forward or backward to get change the day and 24hour clock.
Feb 02, 2012 | Fossil Stella Topring Watch
I don't know how to wind the watch....can you help?
WIND AT THE SAME TIME EVERY DAY. This is extremely important. In order to ensure that your watch keeps good time it must be wound at the same time every day. Most people like to do this at night before bed.
WIND ALL THE WAY. The watch must be wound all the way, or it will slowly lose the proper time and require constant resetting. Also, if not wound all the way, the watch may stop keeping time earlier than expected.
WIND IN THE RIGHT DIRECTION. Most European watches wind clockwise when the face of the watch is pointing towards you. Determine which way your watch winds, and stick to that direction. To figure this out, try to turn it both ways. The wrong way will either be extremely loose, or extremely tight.
Tips & Warnings
Keeping your watch clean and free of dust and dirt will also add to its longevity.
Contact the watch's manufacturer for any special and/or specific care methods.
Don't under or over wind you watch. When you start to feel resistance, STOP.
Aug 17, 2010 | Watches
I have a manual timing watch wont keep time or wind up right what am i doing wrong
Hi
1. You need to first set the time correctly,then wind it and see if it keeps time or not.
2. Most winding wrist watches needs winding every morning in order to keep it working perfectly,maybe you do not wind it everday that is why it does not keep time.
3.If the result is still the same then you might need to replace the winner.
GOODLUCK
Aug 05, 2010 | Watches
Bulova Millenia 100 m,stops running,move it to wind,starts up
When you say "wave wind" do you mean you're waving it around to wind it with the self-winding mechanism? If so, that will only keep it running briefly as you're experiencing. Manually wind the crown about 40 turns clockwise to "fill the tank" and wearing it daily will keep it topped off. Anytime you don't wear it for a day, manually wind it again. As for the cleaning, the inside of the watch doesn't get real dirty but over time the lubricants wear out and thicken which makes the watch run slowly or not as long as it has to work harder to move the gears through the thickened lubricant. A watchmaker can disassemble and clean the old lube out with solvents and then reassemble the watch with fresh lubricants.
Apr 27, 2010 | Watches
Can't get back off to change battery, even with special tool
Looking at the Fossil site, I couldn't find "Arkitekt blue" as a description.
I noted that they have a blue one which is automatic (i.e. self winding) and therefore does not need winding - but it does need to be worn to keep the spring wound up.
The Fossil site has a complete list of their models and selecting one gives you all the details of the watch, including manuals.
I suggest you try a search on the web site.
Jan 02, 2010 | Fossil Arkitekt watch
Submariner Winding Slips
crowbar040, you may have a problem with your mainspring click, which is supposed to keep the spring coiled as it winds. What might be happening is it is sticking and coming undone instead of winding. Or you could have a bad gear in your automatic.
Apr 28, 2008 | Rolex Daytona 116520 Wrist Watch
Omega seamaster
sounds like an auto wind watch,you must wear this watch most of the day to keep it wound up.to wind the crown must be pushed all the way in.
Jan 10, 2007 | Omega Seamaster 2232.80 Wrist Watch
Watches Logo
117 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
