Question about Philips AJ100 Clock Radio
How can we put the aj100 back on the fm mode? I've been trying to change it, but it stays in the am only. Thanks
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
Network initializing problem for Toshiba e studio 200L stays initizing but can't find the network
Try 08-1001 to Reset NIC board
Value: "1: Cold 2: Warm 3: Not reset"
If still occur, perhaps the NIC board problem...
Apr 16, 2012 | Toshiba Office Equipment & Supplies
Radio phillips aj100 stuck on am band cant get it to switch over to fm frequency.
Press RESET under the radio a few seconds. Adjust clock, alarm and radio again. AM gone, FM back on the air...
Jul 26, 2010 | Philips AJ100 Clock Radio
ELECTRIC HEAT STAYING ON IN COOL MODE
Disconnect the white wire from the "thermostat". If the strips stay on its your thermostat wires.
Apr 29, 2009 | Goodman CKL24AR24 Air Conditioner
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
2005 Dodge Caravan Stereo Mode won't go to CD
i would take back to dealer and tell him it dont work, maybe he forgot to connect a wire.
Aug 12, 2008 | 2005 Dodge Caravan
Getting Out Of F.M. Mode
use the button that looks like a house on the front of the player
Aug 03, 2008 | SanDisk Sansa Clip MP3 Player
Seems to only play in Mono
Karen - Is it only the FM section that is giging you trouble? Does Stereo work for the other inputs - VCR/DVD/Turntable?
Is that stereo button ONLY for the FM section?
May 13, 2007 | Teac AG-V3050 Receiver
Philips AJ100 Clock Radio Logo
85 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
