Question about ASUS A8F Notebook
I have my asus a8f series... i won't be able to enter the bios. when i turn on the system, it doesn't show F2 of DEL to enter the bios...please halp
  • 41 Answers
It will probably only display this option after an incorrect shutdown. It could cause problems but you can pull the plug with the unit running and then plug back in a reboot to get menu you want.
Posted on Aug 24, 2010
How to enter Asus Q534UX BIOS
Windows 10 - How to enter BIOS configuration? - Asus
https://www.asus.com/support/faq/1013015/
  1. Cached
  2. Similar
Hold and press [Shift] then turn off the system. Press and hold the F2 button then click the power button. DO NOT RELEASE the F2 button until the BIOS screen display. You can find the BIOS configuration. Category. Windows 10 - How to enter BIOS configuration? Windows 10 - How to boot the system from USB drive/CD-ROM?
How to enter Asus Q534UX BIOS Google Search
Jan 26, 2017 | ASUS Computers & Internet
Unable to enter Asus 6850 BIOS
I would start by resetting your bios settings to default; turn off your system, remove the side cover and gently pry out the board battery (round "button battery" such as cr2032). Leave it out for about one minute, and reinstall. Then see if you get a post screen.
Dec 29, 2013 | ASUS Computers & Internet
Can't enter bios page. I have a newly built pc (first time) with a asus 8h61-mx series, and when I turn it on, it will not ener bios page when i press F2, del or enter. Any ideas?
First off, on the ASUS website it says to try holding down DEL when the computer turns on. If that doesn't work make sure you have a PS/2 keyboard instead of a USB keyboard, if that works with a ps/2 keyboard then you'll need to turn on USB keyboard support or similar. If that doesn't work, try clearing the cmos, their should be a jumper, and a battery. Put it to clear with the jumper, and remove the battery. Then put it back, and move the jumper back. It should throw a error message saying the cmos and/or bios was reset, and will tell you to press a key to go to the bios.
Sep 14, 2013 | Computers & Internet
Ideapad Z560 neither accessing BIOS setup or is starting normally
Your bios seems corrupted. You will probably need to reflash from a thumb drive which is bootable. The F2 should get you to booting screen to access the thumb drive to boot from to flash the bios.
Dec 23, 2012 | Lenovo IdeaPad Z560 Notebook
What keys change bios values on asus u46e
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jul 28, 2012 | ASUS U46E-BAL6 U46E-BAL7 U46E USB External...
I was told press F2 simultaneously on startup, nothing happened
You need not to press F2 or tab or escape unless you need to do so. If your system is ok, it'll automatically boot up, but if there's boot up problem with your system, then that's different. Thanks for using FixYa.
Jun 06, 2010 | ASUS Eee PC 1000HE Netbook
BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
How to enter bios
Hi...
To enter bios it so easy. When you turn on your computer you just only press delete to enter bios. If the bios does not exist you can press also F2.
Regards
PCmania
Aug 10, 2009 | ASUS Computers & Internet
ASUS A8F Keyboard problem
Sounds like your keyboard needs to be replaced.
Oct 26, 2008 | ASUS A8F Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
ASUS A8F Notebook Logo
116 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
