Question about Kelvinator Refrigerators
THE FRIDGE IS LEAKING WATER FROM THE INSIDE AND RUNNING OUT THE FRONT OF THE FRIDGE
  • 86 Answers
Hello
There is a drip pan under the evaporator coil. This pan is to catch the condensation dripping off the coil. Then the water goes down a drain hose to a re-evap pan. That all being said. What's the problem you have? The first thing I look for is to make sure the hose is still connected to the drip pan. The next and most ofter is the problem is a clog in the drain hose or where the hose connects to the drain pan. We use compressed gas to blow out the clogs.
I would also check the pan for cracks or holes. This should take care of your problem. Also make sure the door and gasket is sealing to keep air and moisture from getting in and making the condensation problem worse.
I hope this helps you. Please leave feedback.
Thank you.
Posted on Aug 24, 2010
Water leaking out from inside and running out under the fridge. Do I need to clean out the outlet pipe and if so where would it be??
Check the drain tube that leads to the defrost pan under the fridge. The drain tube maybe plugged. Do you have water standing in the bottom of the fridge and if so that is probably the problem. However, something must be defrosting inside the fridge to create that much water. Be sure your fans are running inside the fridge.
Jan 08, 2016 | Refrigerators
How to fix water leaking under front of refrigerator
dose water gather inside the fridge, if so, it may be the drain in the inside back of the fridge is blocked, try cleaning it through with a long pipe cleaner,
or if it has a water dispenser on the front, try removing the plastic plinth at the bottom of the unit and checking the water connection,
Good luck
Nov 12, 2014 | Whirlpool Refrigerators
When i close the door on the freezer side the water trickles down the front panel
This could be a leaking water valve. First thing I would suggest is to turn the water supply off under the sink or behind fridge wherever its located and see if the leaking stops.If so then you'll need to replace the water valve on fridge. If this doesn't work look up inside the ice chute on front of door and make sure the flapper is closing all the way when you get ice. Warm air coming up into freezer because the flapper is not sealing tight can cause water to run down front of fridge.If this is the case there is usually frost buildup on the ice chute on the inside of door.
Oct 25, 2013 | Refrigerators
Leaking under neath front of refrigerator
Usually any defrost water sits in a plastic pan and evaporates away in normal operation. If the pan becomes brittle it cracks and leaks water. Pull the fridge out and look on top of the black pot (compressor) Is there a plastic drain pan sat on top of it?
Sometimes if the fridge is working hard a lump of ice can form on the pipework going back to the compressor which melts causing some water at the front of the fridge.
Lastly, the insulation under the fridge may have broken down, allowing condensation to form and drip. If the drain was blocked, the water would be inside the fridge, not underneath.
Apr 20, 2012 | Kenmore Refrigerators
Water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
Jun 22, 2010 | Refrigerators
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Leak under frigerator
leaking inside of fridge? your defrost drain is plugged and running from freezer into fridge around once a day....
May 24, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator leaking water
Try cleaning out the hose (on the exterior rear). This is the drain from the condenser to the evaporator pan.
May 12, 2009 | Whirlpool 18.8 cu. ft. Top Freezer...
Fridge Leaking water from front right hand corner
yes, get a pipe cleaner and put in to the hole to try and clear if not from the back you will find the pipe which will be clipped to a plastic tray on the compressor. unclip and blow up the pipe this will always clear the blockage.
Oct 19, 2006 | AEG SK78800I Compact Refrigerator
Refrigerators Logo
124 people viewed this question
Top Kelvinator Refrigerators Experts
John Tripp
John Tripp
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
