Question about Dryers
Owohotpoint 7kg aquarius condenser dryer keeps tripping the power when i switch it on have emptied and cleaned all filters water drawers
  • 46 Answers
Is it kicking the breaker if it is check to see what amp it is, if it is a 15 amp breaker you will need a 20amp breaker
Posted on Aug 24, 2010
Condensed dryer keeps tripping out my electric when I turn it on
Disconnect from mains. Remove rear panel and water will probably come out. This water is being flung by the fan onto the heater hence tripping the electric.
cause of water being here is a blockage in the condenser stopping flow into water chamber or possibly but unlikely, failure of the pump
Oct 11, 2014 | Hotpoint Aquarius WD640 Front Load...
Aquarius TCL780 keeps beeping
your pump may not be working then it beeps
Dec 09, 2013 | Washing Machines
My Hotpoint Aquarius Condensor Dryer seems to be collecting water behind the filter unit at the bottom of the machine. The drawer where the water is supposed to collect is empty. I keep the filter unit...
there is a line/tube the runs into the back of the drawer which is clogged, you will need to take like pipe cleaner or a stiff wire and run it into the the drain line/tube , Tim
May 29, 2011 | Dryers
I have a new (1 month old) Hotpoint Condenser Dryer (TCD980G). When it is on the drying cycle it runs for about 30 minutes and then trips the RCD circuit. I have cleaned the condenser filter and the water...
There should be no condensation present if it is a condenser dryer, this is the idea of it.
As for tripping the electrice, then it suggests to me that the steam could be the cause of the problem.
As it is a new dryer, then I would strongly advise you ring Hotpoint service, or ring the help line number in your instruction book.
You can contact them at the following address if needed.
WWW.HOTPOINTSERVICE.CO.UK
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Have a condenser auto 7kg dryer, mod cde107. it doesn't get hot thought it would be the element but the 'empty filter' light keeps flashing even though its clear. if the filter censer was broken would this...
no, it would not sounds to me like your either not getting power to the elements, or they are bad, need to check, power to the unit first, then to elements, when you turn it on finally the elements itself, please be safe if you work on it yourself thks larry
Feb 26, 2010 | Dryers
My Aquarius CTD40 7kg condenser dryer keeps blowing the main electric fuse what can i do to fix it ?
No-but I have exactly the same problem- need a little help here- any one??
Dec 13, 2009 | Hotpoint Dryers
Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Jan 12, 2009 | Hotpoint TDC32 Electric Dryer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
