My miele w3740 wont fill with water ,but will carry on washing then it says a technical problem with a number.......
  • Washing Mach... Master
  • 19,396 Answers
Hi.
The machine not filling and carrying on with the cycle is quite unusual.
If the machine advances through the cycle without filling, and without manually advancing the cycle, then it is either a defective water level sensing (pressure switch), or a faulty timer board.
In this case the job is done testing or replacing water level switch (part is not expensive), then if that does not work, replacing the timer board.
The inlet valve may also be tested.
If instead you have to advance manually the cycle, check inlet valve and pressure switch.
The inlet valve may be tested reading Ohms ats terminal (must have continuity). A definitive test is done energizing the valve.
The pressure switch is more difficult to test. This has three contacts and two circuits. The pressure switch opens one circuit and closes the other when water level has been reached (tub full). It is usually replaced rather than testing it.
Posted on Aug 24, 2010
How do I fix a F53 fault on a Miele W3740 Washing Machine
First, unplug the washer for minutes then plug in and see if it solve the problem, if not then check the carbon brushes on the motor. These are a part which is expected to wear and when they do the motor cannot rotate the drum, which means the speed sensor thinks something is wrong and throws the error.good luck. Fixing an F53 on Miele washing machine
Nov 02, 2017 | Miele Washing Machines
How do I fix a Miele W 2653 Wasker.
Hi dear. You did not mention what fault code but regards rest of your information, I would say 3 factors play up with it.
1- Tacho generator or it's plug faulty on motor
2- Motor Carbon brushes worn out or
3- Power/control unit ELP151-KD faulty.
I can advised to contact your local Miele center to diagnose your machine.Thanks.
Mar 17, 2016 | Miele Washing Machines
Why won't my Miele dishwasher fill with water?
Check the filter screen is not clogged in the water supply hose. Also make sure the supply valve is open. Call Miele technical support at (800)999-1360 M-F 8 am to 8 pm eastern. They can help.
Oct 12, 2014 | Miele Dishwashers
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Jul 25, 2010 | Miele W1903A Front Load Washer
My miele wont wash it starts up then stops an wont drain out then the water intake light comes on
Hi If appliance fills then starts to wash then stops and starts. Then most likely cause is debris in circulation motor. This will require appliance and motor to be removed
May 21, 2010 | Miele 24 in. G643Vi Plus Built-In...
I have opened the drain filter on my miele W3740, but the inside doesn't look like the picture in the handbook. there is supposed to be a bit that goes round. is there another piece to take out before i...
If you are not the original owner - perhaps it was removed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Washing Machines
Miele transit rods stuck
My husband was able to pull it out .
Feb 27, 2008 | Miele Washing Machines
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
