The power light is on, but the ac doens't turn on and doens't blow out air, it looks like its attempting to come on but its struggles. tried different power outlets still nothing.
    President:
  • 3,773 Answers
First check for correct voltage at the wall
Then remove the capacitor and take it to an appliance parts store .
They will check it
Be careful. The capacitor holds a charge even after it is removed.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 24, 2010
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
One of my ac's light is blinking and wont turn on. Is not the control batteries, what could it be?
Laptop Won't Turn on, Blinking lights - HP Support Forum ...
h30434.www3.hp.com > Laptop & Notebook > Boot
Solved: Hello My laptop is an HP pavillion dv6z-1100, its running a 64 bit version of windows 7 ... Message 1 of 38 (164,169 Views) ... Upon attempting to turn it back on (while being plugged into the ac adapter) the computer would power up, ...
Air conditioner light blinks - Discussion on Topix
www.topix.com > Chevrolet Malibu
Jul 11, 2006 - my 2001 Malibu has this problem, blinking A/C light. ... On the control panel for the air conditioner, the ac button(the one with the little green light) blinks on ... The ac will turn itself back to outside air after it has been running on ... 2002 A\C Blinking
May 14, 2007
2003 Toyota Camry A/C button flashing
Apr 10, 2007
More results from www.topix.com
Dec 25, 2015 | Computers & Internet
I got Nuttin'
The point of the fuse is that it blows before a surge can damage anything past it. If there's a component that could be damaged with a 3 amp surge for example, the 2.5 amp fuse would blow before the surge gets there but the 3.15 would let it through, and damage would be done.
Jan 26, 2014 | Peavey PVi 4B 4 Channel 100-Watt Powered...
AC only blows when car is moving and hisses
Have you checked the blower motor for power and ground ?
May 17, 2013 | Chrysler Town and Country Cars & Trucks
Hi, my Fujitsu A1220 won't start up at all. I took out the battery to reset the laptop but when I put the battery back on or connect it via AC, it still won't start up. I see the Scroll Lock is brinking...
Here are some ideas to try.
1. Plug battery in and see by looking at the charging light if it's charging. The light should stay mostly constant during this process. If it is charging, then wait about 20 minutes. Unplug laptop and attempt to turn on with just the battery installed. If the laptop turns on, then you can be sure you have a bad AC adapter or a bad DC jack.
Uninstall the battery before attempting the next five steps.
2. Look for the light on the laptop that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, then it's possible you have a bad DC jack or the AC adapter needs to be replaced.
3. Try a different outlet. (I know it's obvious but it's worth a try).
4. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
5. If your laptop has another button that turns it on, such as an internet button, try that button instead of the normal power button.
6. Replace the AC adapter. Find and buy a compatible AC adapter online. You can usually find them reasonably cheap.
7. Replace the switch board and/or the flex flat cable that runs from the switch board to the mainboard. (This requires some technical know-how).
Hope one of these ideas helps.
Good luck and thanks for using FixYa.
Mar 08, 2011 | Fujitsu LifeBook A1220, LifeBook A6210,...
2007 dometic Rooftop AC "high-lo" switch. What does it do?
YES WITH OUT A DOUBT .. DO NOT TRY TO RUN IT ON HIGH IT MAY DAMAGE YOUR GEN SET ... HELP ? PLEASE VOT
May 28, 2010 | Dometic Rooftop RV Air Conditioner
Aiconditioning blows hot air Ford Focus 2004
Your valve that shuts off the hot water to your heater core is not closing.Your AC is running but it is trying to cool down 200Deg. air.May be a issue with the heater/AC contol in the dash or the mixing valve stuck open.
Dec 31, 2009 | 2004 Ford Focus
Analog thermo.stat control kit
Have you tried removing the RH wire connected to the thermostat and try it ? This might rule out furnace as short in system. If it does the same, put RH- (heat) back on and try removing RC-(cool) , if it doesn't pop the fuse, you may have isolated the problem.?
Jul 30, 2008 | Dometic Rooftop RV Air Conditioner
Ac stop blowing
blower morter, look at fuse under the hood
Jun 26, 2008 | 1998 Chrysler Concorde
Furnace will not light, but there is gas to the house
This problem will need to broken down in several steps. First, reset all the breakers that operate the furnace and ac. Turn the thermostat to on and the ac to off and see if the furnace blower starts. Get back with me.
Aug 12, 2007 | Haier HWF05XC5 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
