Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
On a ferguson ted20 tractor which is the primary brake shoe and are they the same on both hubs? that is top on both sides
  • 2 more comments
  • j_g_moran_54 Aug 24, 2010
    I am in process of rebuilding the brakes on my ferguson 20 tractor but I don't know which brake shoe is the primary brake shoe because my instructions are to fit the blue spring to the primary shoe and the red spring to the secondary shoe and both shoes are similar, and is the primary shoe in the same position on both hubs
    Regards John
    I am trying to find out which brake shoe is the primary shoe and which is the secondary shoe so as to determine which spring goes where,
  • j_g_moran_54 Aug 26, 2010
    It was helpful but the shoes are mounted on the top and the bottom of the hub unlike a car where there are mounted at the front & rear of the hub, so I can take from your solution that the bottom shoe is the primary shoe.
    Regards & thank's
    John
  • robert black Dec 18, 2012
    the short spring goes toward the front of the tractor leaving the long spring to the adjuster
  • 11,800 Answers
The primary shoe is always the one that when activated its action is enhanced by the friction generated by the turning wheel - the one on the front of the tractor side. The secondary is the one in which the movement of the wheel tends to minimize its effects - the one to the back of the tractor.
Posted on Aug 25, 2010
    President:
  • 986 Answers
Yes they are the same,are you having any oil leakage from you axle,if you do you will have 2 seal, just replace the inner seal it cheap
Posted on Aug 24, 2010
Yes, they are the same on both hubs and sold in a set of four. Click on the link below to view:
http://www.fixthatferguson.com/index.php?main_page=product_info&cPath=2_6&products_id=20
Where would i find the chassis number on a massey ferguson 3115
Climb up into the tractor's seat. Look below the lower left-hand side and lower right-hand side of the steering wheel panel for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to one of these areas of the steering wheel panel.
Serial Number Plate:
http://old20tractorparts.com/mf-165-tinwork-parts/1356-massey-ferguson-165-serial-number-plate.html
Inspect the left- and right-hand sides of the tractor's main frame. Certain older Ferguson tractors have the serial number stamped to a plate on the outside of one of these areas of the main frame.
Inspect the top of the transmission housing for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to the top of the transmission housing.
Jan 27, 2014 | Aprilia Pegaso 650 i.e Motorcycles
I cant find brake shoes for a latter model TE20 ferguson tractor
Found my files. Go to Wengers.com ferguson tea 20 brakes # 1810352m , if it looks like yours , call for size or maybe some advise. good luck.
Dec 18, 2012 | RTO Massey-Ferguson Tractor TE20, TO20,...
Can get linings for big drums brakes 2"W x 15-1/2"L from Steiner and they are for Ford 9n 2n. I had to use them on my to-20 because of it has tea-20 brakes system,really confusion and took a long time to find what would work. If you need the complete shoe they have a setthat could work. Call them and ask a rep. but linings and rivet tool are a lot cheaper if you can get by. If this don't work let me know ,I have another sorce on file somewhere. Always check Ford N series for parts, they are alot alike because of Ford Ferguson partnership.
1960 massey ferguson hydraulic filter location
Hello, I would say just go to a NAPA parts store and ask for a filter. If they have one they would show a part number for it. Usually the older tractors for Ford and Ferguson did not use filters or at best had metal filters that you cleaned in solvent and reused. There are Repair Manuals in soft-cover which are available at places like Tractor Supply or online.
The old tractor makers considered the transmission and differential sealed systems. This means like your new car today does not have a filter in the differential. The old tractors had manual transmissions and the filters are common in automatics.
Be careful not to overfill the trans because on old tractors the gear lube will go out the axle tubes and into the brakes. If operated on a slope, it is possible to tilt the axle tube and have the excess lube flow into the low side axle tube, ruining the brakes.
Some of the parts for the Ferguson will interchange with the N Series Ford. Ferguson had some Industry innovations that later were stolen by other makers.
Oct 03, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
What oil do i need for the engine of my ted20 and also what oil do i need for the hydro / rear end and how much.
use 30w in the engine and for trans/hydraulics use massey m1129 or get the Travellers brand for that m1129, most farm stores will have it.
Jul 04, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
How do you change rear drum brake shoes on a 1999 couger.
SECTION 206-02: Drum Brake 1999 Cougar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 09/14/2001 Brake Shoes Removal
  1. Loosen the wheel nuts.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02.
  1. Remove the wheel.
  1. Release the brake shoe automatic adjuster.
  1. Remove the brake drum.
    1. Remove the retainers (if equipped).
    1. Remove the drum.
  1. Make sure that the hub flange is in the correct position as shown.
  1. Remove the hold down springs.
  1. Disconnect the parking brake cable.
    1. Lever the secondary shoe outwards.
    1. Disconnect the cable from the secondary shoe.
  1. Disconnect the shoes from the anchor block.
    1. Remove the lower return spring.
  1. ani_caut.gif CAUTION: Do not damage the wheel cylinder boots.
    Detach the shoes from the wheel cylinder.
  1. Hold the wheel cylinder pistons in place with a rubber band.
  1. Remove the upper return spring.
  1. Remove the primary shoe from the strut and brake shoe adjuster.
    1. Rotate the adjuster counterclockwise.
    1. Remove the primary shoe.
  1. ani_caut.gif CAUTION: Take care as the strut support spring is under tension.
    Detach the secondary shoe from the strut support.
    • Detach the strut from the shoe by levering the strut against the shoe.
  1. Remove the parking brake return spring.
Installation
NOTE: Install new shoes as axle sets.
  1. Clean, check and apply Silicon Dielectric Compound D742-18A331-A or equivalent meeting Ford specification ESA-M1C171-A to the backing plate contact points.
  1. Install the parking brake return spring.
  1. Install the secondary shoe to the strut and brake shoe adjuster.
  1. Install the primary shoe to the strut and brake shoe adjuster.
    1. Install the primary shoe.
    1. Rotate the adjuster fully clockwise.
  1. Install the upper return spring.
  1. Remove the rubber band holding the wheel cylinder pistons in place.
    Position the shoes to the wheel cylinder.
  1. Position the shoes to the anchor block.
    1. Install the lower return spring.
  1. Install the hold down springs.
  1. Install the parking brake cable.
    1. Install the cable to the secondary shoe.
  1. Install the brake drum.
    1. Install the drum.
    1. Install the retainers (if equipped).
  1. Install the wheel.
  1. Operate the brake pedal to achieve automatic adjustment.
2010&c18=modelyear&c20=g167866&c35=wsm%2cbrake%20shoes%2csxu%2c206-02%2cremoval%20and%20installation&s=1249x702&c=32&j=1.3&v=y&k=y&bw=910&bh=359&ct=lan&hp=n&[aqe]
Mar 05, 2011 | 1999 Mercury Cougar
How to remove rear brake shoes
How to Replace Brake Shoes
(DIY Complexity: Moderate / DIY Time: 3.2 hours)
Parts:
1. Brake Shoe Set
Tools:
1. Combination Wrench Set
2. Floor Jack
3. Jack Stand Set
4. Mallet Hammer
5. Brake Spring Tool
6. Flat Head Screwdriver
7. Needle Nose Pliers
8. Tire Iron
9. Brake Resetting Gauge
Supplies:
1. Brake Cleaner
Steps:
Step 1 * Secure your vehicle on a level surface, making sure your car will not roll or lean when jacked up.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 * Break the lug nuts loose but do not remove. Lift up your vehicle using a floor jack.
o Tip: Using an aftermarket floor jack, instead of the original equipment (OE) jack, can make the job easier and safer. Verify the condition of the floor jack before use.
o Tip: Lug nuts fasten the wheel to the hub and may be on very tight. To gain more leverage, use a breaker bar to loosen the nuts.
Step 3 * Secure the vehicle with jack stands on both sides for safety before starting any work. Do not rely on the jack to hold the vehicle up while working.
Step 4 * Remove the lug nuts. Remove the wheels.
o Tip: Make sure the parking brake is released before removing the brake drum.
Step 5 * Remove the brake drum. If necessary, back off the star wheel adjuster.
o Tip: Hit the brake drum with a rubber mallet to break it loose from a rusted hub.
Step 6 * Clean the brake assembly using a“wet wipe method”. This method uses a spray bottle with water and detergent. Do not use compressed air to clean the brakes. Inspect the brake shoes for wear or damage.
o Tip: It is a good idea to leave one side assembled to use as a reference while you work on the other side.
Step 7 * Remove the primary and secondary brake shoe return springs from the anchor pin and brake shoes.
o Tip: The primary spring is connected to the front (primary) brake shoe and the secondary spring is connected to the rear (secondary) brake shoe.
Step 8 * Remove the adjuster cable and spring assembly. Remove the star adjusting screw and thread the adjuster all the way in.
Step 9 * Remove the front brake shoe retainer. Remove the front brake shoe and parking brake link.
Step 10 * Remove the parking brake lever from the rear brake shoe. Remove the rear brake shoe retainer and remove the rear brake shoe.
o Tip: Specialty brake tools are available to make brake shoe removal easier; but it is possible to remove the brake components with pliers.
o Tip: While you have the drum brake assembly apart, pry the outer seal away from the wheel cylinder and check for leaking brake fluid. If any brake fluid is leaking, replace or rebuild the wheel cylinder
Step 11 * Apply white lithium grease to the backing plate contact points.
Step 12 * Install the new brake shoes in the reverse order of removal. Be careful to keep the new brake shoes clean.
Step 13 * Inspect the brake drum and resurface or replace if necessary. Install the brake drum and adjust the brake shoes.
o Tip: There is a slot on the back of the backing plate usually blocked with a rubber grommet. To adjust the brakes, insert a screw driver into the slot and turn the star wheel adjuster. Spin the brake drum and stop adjusting when you feel a slight drag.
Step 14 * Install the wheels. Torque lug nuts to manufacturer’s specifications.
Step 15 * Lower vehicle and test drive to verify repairs.
Hope help with this (remember rated and comment this help).
Mar 11, 2010 | 1988 Toyota Pickup
Which brake shoe is the primary shoe on a 1998 pontiac grand am? front or back
I'm assuming you mean drum brakes as they are the only ones with primary and secondary shoes. Not all drum brakes have a primary and secondary shoes. On drum brakes with primary and secondary shoes (called duo servo systems) the front shoe is slightly smaller than the rear one and is the primary shoe. On non servo systems, the shoes are the same size -- there is no primary or secondary shoe.
Nov 17, 2009 | 1998 Pontiac Grand Am
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
530 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
