Question about Refrigerators
MOTOR NOISE - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Kenmore model 2130 washer guide
This nut is most likely a nut which secures the motor to the motor mount. If the motor is no longer secure, it will make a lot of noise, and also probably move. Call a professional to have the motor re-secured to the motor mount.
Sep 29, 2014 | Washing Machines
Inducer motor noise
Replace the motor.
Jun 29, 2017 | Water Heaters
Inducer motor noise
Never trust anything that comes to you new because usually they are made in china and are not consistent, but next time make sure clean air is being supplied if impeller gets dirt build it becomes imbalanced and will draw high amps and create that vibration noise. Also vibration noise can be caused by improper combustion set up.
May 15, 2017 | Water Heaters
BUZZING NOISE
Is this noise a motor buzzing noise? If motor has power but the start circuit is not energized, then the power through the run winding cannot start the motor and may make a buzzing. Need to address the type of buzzing and if the motor, then check motor circuit.
Jan 08, 2014 | Hoover Dryers
My tumble dryer is making a noise when on and drum is not turning
Either
-the drive belt has slipped off or snapped (revving motor noise)
-the belt tension spring has broken (revving motor noise)
-the motor start capacitor has failed (heavy hum noise)
Nov 25, 2013 | Dryers
Have a Bocsh WTMC 3321US/03 drier making noise. i have replaced motor, same noise. with drum not turning and belt disengaged, making same noise. What do i look for next??
If a noise is heard or even a HUM you can use a small tube to probe with one side kept to your ear. Trace the noise to the actual unit , if this is the motor humming check the capacitor as a faulty capacitor will not start the motor.
Also check for free movement of the motor drive as if there is tightness in the drive the motor will not work.
Nov 05, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
MOTOR NOISE and noise stopped after closing the fridge door
Hello
Is the noise on the inside or the outside? Most often noise is caused by one of the fan motors going bad.That being said. If the noise is on the inside it's the evaporator fan motor. If it's on the outside in the back then it's the condenser fan motor.
I hope this helps you. Please leave feedback.
Thank you.
Aug 24, 2010 | Refrigerators
Motor noise
If your washing machine is making a high-pitched whine or squealing noise
while running,the main culprit is usually worn motor bearings.To check the
motor bearings,remove the belt and run the motor by itself,listening for the
noise.If it makes the noise,than the problem is most likely the result of worn motor bearings.
Apr 08, 2010 | Whirlpool Washing Machines
Noise from the fan/fan motor
The bushings in the motor are worn out, replace motor. This should correct the problem.
Sep 10, 2009 | Refrigerators
Noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
May 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
