Question about Smeg WDI12 Front Load Washer / Dryer
My smeg washing machine stopped half way threw cycle its now showing e06
  • 1 more comment
  • catpub09 Aug 24, 2010
    HI IVE CHECKED FOR BLOCKENG THERE NONE THE CYCLE PNEL ON THE FRONT IS GOING MAD BLEEPING AND SHOWING DIFFERENT NO:S IS THERE A RESET SECENSE I HAVE TO DO?SEEMS LIKE IT DOESNT NO WAT TO DO?
    yes ive done that its clear and the water is being pumped out into the waste pipe but it will not go threw its cycle now the digital panel on the front is beeping and showing all different no not codes is there a reset button or secuence i have to do to reset it?
  • Anonymous Mar 26, 2014
    The machine stops and shows E06
    President:
  • 1,554 Answers
It is a code for draining problem. Pop the filter cap at the bottom front of the machine then drain the water through the emergency drain hose into a shallow pan or basin. If emergency drain hose is not present, place the pan or basin in such a way that it catches the water when the filter is removed. Remove the filter by turning it counterclockwise and clear it from any debris that might be blocking the water from draining out properly.
Once the filter is cleared, screw it back into place and plug the emergency drain hose then stuck it in and reinstall the filter cap.
Fill the machine with water then manually drain it by pulling the end of the drain hose and placing it into the basin. In this manner, you will now if the drain hose is clogged or not. Make sure the drain hose is not clogged or kinked and water flows properly down the drain hose.
You can tell that the drain pump is not working and needs to be replaced if the filter is clear, the drain hose is not clogged/kinked and water is flowing perfectly during the manual draining.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 24, 2010
  • Jahn27
    Jahn27 Aug 24, 2010
    You can reset the machine by pressing “Start/Pause/Cancel” button for 3 seconds. Unplug the machine for at least 30 minutes to forcibly reset it if pressing the button does not reset it.
  • Jahn27
    Jahn27 Aug 24, 2010
    least 30 minutes to forcibly reset it if pressing the “Start/Pause/Cancel” button does not
    reset it as stated in the previous post. If the display seems to be scrambled, it signifies a faulty control panel electronics.
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
Neptune tl washer will go half way threw cyle,start to spin,stop and start to spin,stop and start to spin .tried to unplug it restart and nothin, tried different settings still nothing. tried moving the...
If your machine is a FAV6800A to FAV9800A here is the Service Manual.
If it one of those machines I suspect a possible clutch malfunction.
See this post for what is involved to do clutch maintenance or replacement.
Do you have any error codes to the display if it's a FAV6800A such as dC or uC unbalance codes. Is the wash tub banging around on Spin Cycle of the Wash Cycle? ……Rich
Feb 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Smeg wm16aaa error code e06 Can anybody help me on the above please
HEre's a link to Smeg's web site with all the error codes:
http://www.smeg-service.co.uk/support/index.php?a=1#1
The only problem is that the code doesn't really tell you a lot though apart from it's probably not draining properly. Does any one have any ideas for E06?
G
Nov 08, 2008 | Smeg WM16AAA Front Load Washer
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Smeg WM 16 AAA WASHING MACHINE
Try turning power off, unscrewing the back panel of the machine and removing, reaching inside and giving the wheel which looks like a waterwheel (has 'fans') a couple of turns. This is the pump and sometimes small particles jam the wheel. Turn the power back on and if still in mid-cycle should resume and finish.
Apr 12, 2008 | Smeg WM16AAA Front Load Washer
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
WDI12C Machine Will Not Drain - Error Code E06
remove the two wires from pump connect two wires with a test bulb. this would eliminate the control issue if the bulb lights. 240 volt bulb. take it from there
Nov 24, 2007 | Smeg WDI12 Front Load Washer / Dryer
Smeg DI 612CA
Take a look at this link http://www.smeg-service.co.uk/support/index.php?a=1&cat=4
Would seem to be the anti flooding device on the inlet hose
Nov 19, 2007 | Smeg 24 in. STX2 Built-in Dishwasher
Smeg Washing machine
This happened to us before and we had to actually reset the unit. I had to call the tech support and they walked me through the process.
Mar 25, 2007 | Smeg WDI12 Front Load Washer / Dryer
Smeg WDI12 Front Load Washer / Dryer Logo
325 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
Jorge Rendon
Jorge Rendon
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
