Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Sir i have a printer in mfp 1522 hp,thats problem error is Used black cartridges only in always time,but not printing,through my computer,that all ready connected to this computer plz help..
  • 223 Answers
Try doing a nvram. Take out the paper and the toner and turn off, hold down the down arrow and the cancel button and turn the printer back on while still holding. Hold until permanent storage init is displayed.
Al
Posted on Oct 01, 2010
My hp color laserjet cm3530fs mfp black cartrigde is bringing out faint black colour, how do i fix it?
What is the status of your black cartridge? Is it new? used? Real HP cartridge or 3rd party. 3rd party are notorious for poor print quality. I would test a different black cartridge first to eliminate that as the problem. Post back your results and I can provide further guidance.
Feb 26, 2016 | HP CC520ABAPR Color LaserJet CM3530FS MFP...
Vertical lines print on the document
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Dec 06, 2012 | HP LaserJet M1120 MFP All-In-One Printer
WHENEVER I PRINT I GET A GREY BACKGROUND IT LOOKS LIKE DUSTY PAPER BUT IT ISNT? WHY IS THIS?
If the black toner cartridge (Q6000A) is not original, problem with the doctor blade, bad calibrated.
Use Original cartridges?
See This:
The amount of background toner shading becomes unacceptable.
1.The media might not meet HP specifications.
  • Use a different paper with a lighter basis weight.
2. Use a different paper with a lighter basis weight.
  • Check the MFP environment.
3.One or more print cartridges might below. If non-HP print cartridges are used, no messages appear on the control panel or in the HP ToolboxFX.
  • Replace any low print cartridges.
Aug 03, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Hp lasejet M1120 MFp printer error massage supply memory error
There is either a problem with the reader on the printer (unlikely) or the chip on the print cartridge is bad (more likley). You may be able to push the checkmark to continue printing, but some of the HP products will not work when this error is present. Try a different cartridge to determine whether the printer or the cartridge is to blame.
May 05, 2011 | HP LaserJet M1120 MFP All-In-One Printer
I have a printer hp 1522 and I used a new cartridge in it but the message " used black cartridge in use" warned me why and how can I solve it
I THINK THE CART. YOU ARE USING IS REFILLED MORE THAN ONE TIME (CHECK FROM YOUR SUPPLIER) IF NOT. THEN GO FOR THE CHANGE OF CHIP IN CART. IT WILL BE DONE.
Feb 04, 2011 | HP LaserJet M1522n MultiFunction Printer
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
Print cartridge prob [tri-color] refer to ... doc to troubleshoot
HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
Normal catridges recommened by HP are given below :
01. HP 901 - Black which will print 200 Pages.
02. HP 901 - Tri Colour which will print 200 Pages.
03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
This printer is most rugged one used by Home as well as in offices.
The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
  • Print, copy, scan and fax with a single machine
  • Print fast, at up to 28 pages/minute black, 22 color##
  • Fax at speeds up to 33.6kpbs
  • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
  • Preserve important documents for decades without fading1
Solution:
Please use the originai catridges for this printer and there will not be any issues.
In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
Jul 21, 2009 | HP Officejet J4680 InkJet Printer
Check print cartridge error
Set the properties to print on HP paper. This usually solves the problems
Mar 09, 2009 | HP DeskJet 3745 Printer
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
1,219 people viewed this question
Seeker5211
Seeker5211
