Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Hi ya. we have a fisher and paykel nautilus dishwasher. and it has a fault. f4 is on the panel. and its not draining water. help please
  • Fisher and P... Master
  • 3,247 Answers
This means something wrong with the water heater.
Most likely you will need to replace it. It will look something list this.
Will need a technician to fix it if you are not very comfortable to handle such equipment.
Please rate this solution.
Posted on Sep 03, 2010
Fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
Apr 12, 2013 | Fisher and Paykel Dishwashers
F4 message on the top drawer, fisher paykel. I clean the filters and arm every week or two.
There 2 possibilities with this error:
1)
  • Fault with water fill (only on machines with level-controlled fill)
  • Note: Lights blinking, pump running and controls dead indicates an over fill fault
2)--4 Flashes--Draining failure. Drain pump, control board OWI or water indicator defect
God bless you
May 14, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained ...do these dishwashers have a reset button?
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
F4 error fisher & paykel nautilus dishwasher sometimes this error comes up and it seems to occur about 10 minutes from the end of the cycle. it doesn't happen all the time. the user guide does not...
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error. Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
Mar 08, 2010 | Fisher Dishwashers
Fisher & Paykel Nautilus Dishwasher
F4 is a fault code telling the controller that the water is not heating up. This can be caused by either a faulty heater plate, a bad connection between the plate and controller, or the controller itself. If you wish to fix this yourself, changing the heater plate is a fairly involved repair and should be done by someone with a high degree of mechanical ability.
Dec 09, 2008 | Dishwashers
What is F4 error on fisher paykel dishwasher?
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
607 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
