Question about Hyundai ImageQuest L50S 15" LCD Monitor
Mo9nitor is plugged in but only comes on for a second and dies
  • prioritycont Aug 24, 2010
    You have either a bad Power Control Assembly, a bad Power Control Board, a blown fuse, or a loose connection inside the monitor? We can trouble shot several ways. Do you have another Monitor?
  • Hyundai Master
  • 17,129 Answers
It is possible that the main board has some dry solderring joints. You will need to open the main board and check with a good lighting, a magnifying glass for finding the fault. Look for faulty connectors.Push them in and keep all connectors tight.
When the set cuts off check to see after disconnection of power if any of the components are heating up. If so check and see the reason ,may be drypoints must be checked on these components.
Check the voltage at the power on and off condition which can be a good indicator to the fault area.
Hope my advice helps.
Posted on Aug 24, 2010
At idle the engine revs up and down and after a few seconds it dies.
check PVC and egr valves they cause many problems when plugged up
Apr 20, 2015 | Cars & Trucks
Car froze one cold night, plugged it in a day later, tried to start it after it was plugged in for an hour, started for 5 seconds then died, started again, backfired then died, Tried boosting it, turns...
It will be good to have some hot water poured on to the radiator and engine without any on the electicals . If possible you can remove the plugs and clean and heat them before it is set back.
Have the battery charged before this so as to have a good cranking.
The cold engine needs a good spark to come to life. so try this out.
Feb 17, 2011 | 2000 Pontiac Grand Am GT
I have a tom tom 340s xl. we were on a trip and the tom tom died. it will not come back on. what can I do?
if the battery went flat and the device switched itself off, plug into power supply and press and HOLD the power button for a few seconds until the unit powers up again. Can take 3 - 4 seconds
Oct 05, 2010 | Tomtom GO 300 GPS Receiver
Power light suddenly went out. If I unplug, wait, and plug back in, the power light comes on momentarily, then goes out again.
Same problem here with IP4000. Power light comes on for a second and then dies. Let me know if you get a resolution.
Jan 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My viewsonic mo9nitor says analog not digital on
To clarify, you know that analog is referring to the VGA 15 pin video input, and digital is referring to the DVI video input, right? You can't have the digital video unless you use the DVI input, which requires a DVI output from your computer (and a DVI cord of course).
If you already knew this and you mean that it won't switch over to your DVI, then there could be several problems. Most of them being with your DVI signal source (computer). Try booting the PC with ONLY the DVI cord attached between the PC and the monitor. If you have a VGA cord plugged into either, UNPLUG IT FROM BOTH ENDS.
Dec 05, 2009 | ViewSonic Computers & Internet
95 Dodge Dakota 4 Cyl Dies
try replacing the coil, my 2.5 did the same thing, and after changing plugs,wires,distributor,rotor,rotor button . the last thing i repalced was the coil and i have not had an issue since. all work was done about 6 months ago.
Jan 08, 2009 | 1995 Dodge Dakota
Car dies when driving,check engine light comes on.
There is a good chance it could be your fuel pump , however if the check engine light is coming on and the dealer cant tell you what is wrong , try a different dealer or another shop. Second opinions never hurt.
Dec 12, 2008 | 2002 Kia Optima
CAR CUT OFF WHEN DRIVING
Have u checked for spark? U can pull a plug wire off, install a plug in the wire (saves u from taking a plug out), place plug on metal surface, crank engine while someone watches for a spark. If no spark check coil and ignitor (inside distributor). If u have spark check to see if u have gas making it to plugs. Crank engine over (no more than 10 seconds, give it a 10 second rest, try again for 10 sec. etc, ) After doing this for several minutes, pull a plug and check it--it should be wet from gas. If the plug is dry, u aren't getting gas (change fuel filter, check fuel pump). countrycurt0
Sep 27, 2008 | 1992 Honda Accord
92olds cutlas cierra, 3.3 liter
how do you check your coils is there a photo that shows you how? or a video, web site
Jun 26, 2008 | 1992 Oldsmobile Cutlass Ciera
Hyundai ImageQuest L50S 15" LCD Monitor Logo
70 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
rhodesworks
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
