Installing external USB Hard drive - Computers & Internet
How do you "format and make partition". You are talking to someone who knows nothing about computers.
Posted on Nov 11, 2008
    Genius:
  • 2,785 Answers
Put in one of the usb slot and format and make partition
Posted on May 05, 2008
Tip
How to Install an Operating System on an External USB Hard Drive:
You may have an external hard drive you want to use for more than just document backup.
In this situation, you can install an operating system onto your external hard drive. By doing so, you will be able to run your external hard drive as a fully functional operating system.
If your primary hard drive ever crashes, you will have a backup option unavailable to those who simply use their external hard drives as file and document backup.
1) Plug your external Hard Drive into your Computer using the USB cable. Insert the installation disk for your Operating System into the CD/DVD Drive. Turn on or restart your Computer.
2) Boot from the installation disk. You may have to press a key once prompted to boot from the installation disk.
3) Accept the license terms and conditions. Read through these carefully if you wish to understand your legal rights as a user. If you disagree with these terms and conditions, you may want to purchase a different Operating System.
4) Choose your destination drive. Your external Hard Drive will likely be the E: or F: drive. By default, the C: will represent your main Hard Drive and the D: will usually represent your CD/DVD Drive.
5) Begin the installation. Your external Hard Drive will install the Operating System. You will now be able to run that Operating System off of your external hard drive.
Hope this helps.
on Sep 03, 2010 | Computers & Internet
External hard disk drive does not appear
Rupert, You may need to install the drivers for that hard drive. Since you didn't mention the type of operating system you're trying to install the hard drive on (PC vs. Mac), make sure the external hard drive meets the operating system requirements.
If this is a USB external hard drive, make sure the USB controller is set to "enabled" in the BIOS
If the hard drive requires an external power source, make sure that its plugged in.
Check the "device manager" settings for any conflicts with the USB controller or with the disk drives- make sure the device is working properly and that it is enabled.
Mar 22, 2015 | Samsung Computers & Internet
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
My hard drive is not being recognize
Jan 06, 2013 | Computers & Internet
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
I can not get into my external drive. The blue light comes on briefly and then goes out.
  1. Plug in and turn on the external USB hard drive
  2. Right mouse click on My Computer
  3. Left click on Manage
  4. Left click on Device Manager
  5. Expand the USB list
  6. Find the USB device for your USB Hard Drive (in my case it was the one that had no description)
  7. Right mouse click - Uninstall
  8. Turn off the external USB hard drive
  9. Turn on the external USB hard drive and let it find and install the driver
  10. It should work
Try this
Dec 14, 2010 | Hitachi Computers & Internet
How to install os in usb hard disk
First plug your external hard drive "disk" into your computer using your USB cable. Then insert your CD/DVD in your CD/DVD Drive "D, or E, or F" that are define in your system and turn off your computer and On your System "computer". Then boot form the installation disk. Begin the installation so that the hard drive will install the operating system. Then accept the license terms and conditions. Then choose your destination drive."By default, the C: will represent your main hard drive and the D: will usually represent your CD/DVD drive. So your external hard drive will be the E: or F: drive. "And you will now able to run that operating system."
N.B: "You will be able to run your external hard drive as a fully functional operating system. If your primary hard drive ever crashes, you will have a backup option unavailable to those who simply use their external hard drives as file and document backup."
All the Best!
Oct 18, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I just got my external hard drive, used once, now won't turn on
Check the USB cords and then make sure updated drivers for USB are installed.
Aug 29, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB Problem
hmmm external hard drive should work without any problem as windows xp allready have inbuilt drivers for mass-storage.
try to Uninstall the USB driver, goto Device manager and Uninstall USB, then reboot to clean system registry and install USB driver from Windows XP setup disck. and try the external-hard drive, xp should recognize your external-hard drive. If not then install driver for your drive if you have and try. for camera and ipos u need to install drivers and supporting softwares from your manufacturers.
thanks
Iqbal
Mar 31, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
