Question about EliteGroup P4VMM2 Motherboard
Need layout of panel 2 - EliteGroup P4VMM2 Motherboard
    Sergeant:
  • 203 Answers
Ok here is a link for the Manual download for you, there are many different Versions, check yours 1st then select the 1 you need. Thumbs up please if it's any use to you, thank you.
http://www.ecsusa.com/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=8&keyword= P4VMM2
Posted on Aug 24, 2010
  • 4 more comments
  • Ytee
    Ytee Aug 24, 2010
    link wrong this 1 http://www.ecsusa.com/ECSWebSite/ECSSear...
  • Ytee
    Ytee Aug 24, 2010
    Hmmm link not copying fingers cross this 1 pastes all. http://www.ecsusa.com/ECSWebSite/ECSSear...
  • Ytee
    Ytee Aug 24, 2010
    Ok 3rd time lucky, this takes you to another forum. You need to register there to see the link in 'Technical' under 'General Technical Issues' cheers Ytee
  • Ytee
    Ytee Aug 24, 2010
    lol did not leave the link so sorry here it is. If it is not clickable copy and paste it into your address bar. http://www.yo-lid.co.uk/forum/viewtopic....
  • Ytee
    Ytee Aug 24, 2010
    www.yo-lid.co.uk/forum/viewtopic.php?f=32
  • Ytee
    Ytee Aug 24, 2010
    I give up, register in forums @ yolid.co.uk and look in 'Technical' under 'General Technical Issues' for your manual download link. In that manual should be the layout you are looking for.
How to make at sign work on asus laptop?
If your @ sign is not working it is probably a regional setting in your control panel. Your Keyboard is probably set to the the wrong layout
This will be slightly different for Windows 7 vs Windows 8 so check the control panel for Regional settings, input, keyboard settings. you will need to change your keyboard layout. If the @ sign is ontop of the number "2" then select US otherwise select UK. That should help.
Aug 31, 2014 | ASUS Eee Computers & Internet
My rear wiper stopped working all of the sudden cant find fuse for it. HELP!!!!
There are 2 fuses that have something to do with the rear wiper. I have "kind of" a diagram of the fuse layout. The fuse panel you want to look at is located in the kick panel on the passenger side of the vehicle (by where your feet are on the right if sitting in the vehicle) Below is that "kind of" diagram of the fuse layout. I have marked the 2 fuses you need to check. They should both be 20 amp fuses (yellow). I hope this helps and good luck.
Nov 24, 2011 | 1995 Jeep Grand Cherokee
Cannot use the pound sign, or the @ and " without having to use Shift 2 and Shift @ accordingly. I just want to make use of the keys displayed on the keyboard as presented.
Hi, did you check your layout settings ? Control panel, Languages and regional options, Input, then select the right layout, Make sure you do not have many diiferent active layout, you might have switched the layout by accidental keystroke. Thanks and have a nice day J -
Jun 07, 2010 | Logitech EX100 967499-0403 Keyboard
Hi my keyboard is typing wrong keys when I pressed them...not all.but some keys when shift key is pressed along with 3.It is not printing hash..instead printing someother character. Also if I press...
Did you check your layout options ? Go to control panel, then regional options, then Input, then select the right layout.
Make sure you do not have several active layout, you might have switch the layout with a keystroke ! Thanks and have a nice day Julien
Jun 07, 2010 | Computers & Internet
I need to install or downloads Arabic language into my computer languages so I can type using Arabic keyboard thank you very much sam
Setting Up Arabic in Windows XP
Adding the Language to Windows
The following instructions will help you to set up your keyboard layout for Arabic that matches the DataCal Keyboard Labels.
Step 1. Install Supplemental Language Support
The Arabic language requires that you install Supplemental Language Support before you can set it up in Windows.
  1. Select the Start button in the lower left corner of the Desktop.
  2. Select the Control Panel (or, if you are using the Windows Classic Setting, select Settings > Control Panel).
  3. In the Control Panel, double-click the Regional and Language Options item.
  4. In the Regional and Languages dialog box, click on the Languages tab. In the Supplemental language support section, click on the Install files for complex script and right-to-left languages (including Thai) option (see Figure below).
  5. Click on the Apply button in the lower right corner of the dialog box and then click on the OK button. You may be prompted to insert your Windows install CD into the CD drive.
Step 2. Add Language to Windows
  1. In the Control Panel, double-click the Regional and Language Options item.
  2. In the Regional and Languages dialog box, click on the Languages tab.
1. Click on the Details button in the Text services and input languages section of the Language tab to open the Text Services and Input Languages dialog box.
2. To add a language, click the Add button in the Installed services section to open the Add Input Language dialog box.
3. Click on the arrow to the right of the selector in the Input language selector and scroll to Arabic.
4. The Keyboard Layout/IME should default to the Arabic keyboard layout. If it does not, click on the arrow to the right of the selector in the Keyboard layout/IME selector and scroll to the Arabic keyboard layout. Note that there often are different keyboard layouts for a language. You should select the language and keyboard layout that matches the DataCal Keytop Label.
5. After you select the language and keyboard layout, click on the OK button to close the Add input language dialog box.
6. When you return to the Text services and input languages dialog box, you will see the new input language and keyboard layout included in the Installed Services box.
7. Click on the Apply button to apply the changes to the new layout. Note that each language features a small blue box in the Installed services section with 2 letters that indicates the language. English is designated as EN.
  1. If you do not wish to add any additional languages or layouts, you can click on OK to close the Text services and input languages dialog box. When you return to the Windows Desktop, you can see the language bar in the lower right corner of the Desktop.
  2. To change the language and keyboard layout, click on the two-letter language selector box with the left mouse button to open the language selector menu.
  3. Click on the language that you wish to use in the language selector pop up menu.
The language you select will remain in effect in active Windows application until you select a different language. For example, if you select the Arabic language and keyboard layout in Microsoft Excel and English in Microsoft Word, each application will use that keyboard layout until you exit the application or you select a different language.
Default Keyboard Layout
If you wish to make a particular keyboard layout the default Windows layout (i.e., to be used in all Windows applications), open the Text services and input languages dialog box.
Select the desired keyboard layout to be the default in the Default input language section of the dialog box.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 27, 2010 | Microsoft Windows XP Professional for PC
How to type the @ key - it is on a key with " and 2 - when I hold down shift key either the " or 2 print but not the @.
Did you tell the operating system to have the keyboard be another language other than english?
Remember its nice to change the language if you need you "ninas" or dashes, but if you need that @ sign you need to change the keyboard language back to english.
Mar 05, 2010 | Acer NSK8458AN Keyboard
I am having trouble to set an e-mail becouse the key @ not popping up but the 2 commas do. can you help me? I am using other computer to ask this question.
Your keyboard is most likely set to the wrong layout, as in it's set as US for a UK keyboard, or vice versa. These keyboard layouts have those two keys the other way around.
To fix, go to Control Panel and find the 'Region and Language' settings (assuming Windows Vista or Windows 7). Click the 'Keyboards and Languages' tab and click the 'Change Keyboards' button.
Click on the 'Add' button on the right and find "English (United Kingdom/States) depending on which layout you have (UK layout has the 'two commas' above the 2) Click the + symbol next to the layout you want and then again next to 'Keyboard'. Click the check box next to the keyboard layout you have (click 'Preview' to check) and then click OK. From the dropdown list in the dialogue, you should now be able to select the correct keyboard layout. Select it and OK out both dialogue boxes.
You should now be typing with the correct keyboard layout.
Dec 31, 2009 | HP Computers & Internet
The keyboard letters appears in a different key for example, the @ key is found on the { key
check the regional and langhuage in the control panel click the lanugage tab click on details if the @ is found on the 2 key the it is a UK keyboard if it is fount on the ' then it is a UK keyboard, you should know the layout, then u can add the correct layout and then rewmove the previous layout
Oct 25, 2009 | Office Equipment & Supplies
The upper case figs ie @ and " have swopped positions how do i get them back to their right postions
The difference in the @ and " symbols occurs between US and UK keyboards, where UK keyboards have the " symbol on the "2" key and US keyboards have the @ symbol on the "2" key.
Regardless of what physical drawing you have on the keyboard, you can change the actions of the keys by setting up the appropriate US or UK keyboard layout in Windows.
First, determine whether you'd prefer a US or a UK layout. In the US layout, pressing SHIFT+2 will write @. In the UK layout, pressing it will write ".
Now, from the Start menu, select Settings and go to Control Panel. Once there, search for "Regional and Language Options". Under the "Languages" tab there is a button labeled "Details". Press it, and a new window opens with the keyboard layouts. Use the "Add" button to select the keyboard layout you want (English, US or UK, Qwerty - not Dvorak), then Remove your old keyboard layout. Press OK and exit all the screens, you're done.
Hope this helps.
Aug 13, 2009 | Compaq Keyboard
@ sign
Could you be using an inappropriate keyboard layout?
Most common issue is US vs UK keyboards, which have the " and the @ sign transposed.
Try typing " and see what you get.
If your @ is above the 2 then you need a US keyboard layout.
If your @ is above the ' then you need UK layout.
If this is the issue, you should be able to change the setting in the "keyboard" part of the control panel.
Sep 12, 2008 | IBM ThinkPad T40 2373 Notebook
EliteGroup P4VMM2 Motherboard Logo
61 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
