Question about Refrigerators
Its freezer is not freezing ice quickly or surface of freezer are not filled from top to bottom
  • 86 Answers
Hello
A common solution to this problem is to clean the condenser coil underneath or in the back of the refrigerator. This will help get rid of the heat and help pull down the temp inside the freezer.
I hope this helps you. Please feedback.
Thank you.
Posted on Aug 24, 2010
Ice has accumulated at the bottom, food at top is slowly defrosting
I believe that the defrost system has malfunctioned. There is a timer that cycles the automatic defrost. The timer shuts off the freezer and turns on a heating element. Then it will cycle back to freezing. If anything goes out in this system the unit will not defrost. over time the cooling fins and below will fill up with ice and the fan can no longer recirculate air so the bottom becomes ice and the top warms up...
Sep 20, 2010 | Frigidaire Freezers
Drain freezes and bottom ices up ii have thawed it cleaned the hose and it does the same thing each time
My be that the unit is not defrosting. There is a timer that turns off the freezer and turns on a heating element to melt the ice in the cooling fins. If this does not happen the fins fill with ice and ice begins to form as the water drips down under the ice. the bottom will freeze and the top will begin to warm.
Sep 19, 2010 | Maytag Freezer MQU2057
The freezer part of the refrigerator is not freezing well. and the top part of the refrigerator is running at approx 63 degrees
Pull the unit away from the wall and unplug it. Remove the front floor plate and rear panels and then vacuum dust and pet hair away. Look for frost on inner walls of the freezer. If you find any ice, try to remove the inside panel and let the ice melt. I used a air dryer to melt the ice quick with an Amana bottom freezer. vacuum the dust and pet hair at least twice a year.
Jun 13, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 | Dishwashers
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
WATER AND ICE INSIDE MY FRIG
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
These are general instrutions for most top freezer refrigs. but if you need more specific directions dont hesitate to ask Thanks Peyton
Mar 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer problems
this particular refrig has only one temperature control which as you know is loated in the refrig section. but temperature isnt your problem. when the icemaker fill tube freezes up like yours has it is generally a sign of a bad icemaker fill valve. the valve seals will go bad and allow water seepage into the line, this seepage will freeze creating a snowball effect freezing the tube. you can use a hair dryer to remove the ice from the tube, and either replace the fill vlave yourself or have it replaced
btw the fill valve is the part that the other end of the fill tube is connected to on the back/bottom of the refrig in the compressor compartment. Good luck and message me back if you have any questions. Thanks Peyton
Feb 24, 2009 | Hotpoint HTS17BCM Top Freezer Refrigerator
Water acculation in refridgerator.
I had a similar problem with my old hotpoint frig (top freezer, bottom frig). the defrost cycle would come on and melt the ice, but since the drain plug in the back of the freezer below the coils would eventually freeze up closed due to ice accumulation. It got to the point I had to shut down the whole unit and leave it open for around 8 hours to let it naturally melt the ice in the drain tube. I hear a gurgle sound and then a sound of water flowing, so I knew it was now draining again.
Jun 08, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
