Question about Miele Dryers
I have a Miele T5206 dryer. It is heating up properly and tumbling as well. The problem is that the air blower is not coming on. Maybe a fuse or a breaker, but where to start looking for that?
I solved the same problem by pressing the three reset buttons on the side of the heater element housing.
Under the machine, remove plastic ducting for exhaust air. Undo the shiny bracket which holds the heater housing in place. Gently pull housing down and when you turn it around you will find (sometimes very covered in fluff) three red reset buttons. press, so they stay in. replace all parts.. Worked for me, with a fairly heavily used machine with alot of fluff build up inside the heater element(this was removed carefully)
Posted on Sep 12, 2011
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 | Dryers
My miele drying machine shut off after a few use then wait for a few days to work again suspect that it got moisture inside.what to do
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Mar 01, 2015 | Miele Dryers
When drying the laundry,(Miele T7744C) water does not get into the properly closed condenser unit at the top anymore but is accumulating on bottom of the dryer, I hear it sloshing under the drum. Also some...
test this steps and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 31, 2013 | Miele T7744C Dryer
Miele Tumble dryer will not produce heat .
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Oct 14, 2009 | Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
My Miele T8002 will turn on, and run through the cycle, however there is no heat and the laundry does not dry. I can't find a troubleshooting guide anywhere on your site, and i was hoping maybe someone...
Try checking the house power supply to see if a breaker has tripped or a fuse has blown, it's possible for the dryer to run if one of the two fuses has blown or one of the two breakers has tripped,
  • the dryers power cord could have burned or broken at the dryers termianl block.
  • the heating element could have burned out.
  • the thermal fuse could have blown.
Mar 30, 2009 | Miele T8005 Tumble Dryer
The drum is not spinning on a miele dryer, model T5206, the appliance is generating heat, the brushes are intact and also the belt on the centre of the drum is intact.
the tensioning device [ spring] is weak or the belt is stretched beyond its usable length. if a new belt has been installed, the tech didn't put the belt on the correct side of the tensioning device. it is possible to install it wrong.
Jun 19, 2008 | Miele Dryers
Miele T5206 drier repair manual
meile t5206 not heating up,everything else working ok. I have ensured all filters and vent pipes clear
May 16, 2008 | Dryers
Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 21, 2008 | Miele Novotronic T220 Electric Dryer
Dryers Logo
334 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
