Question about Canon Office Equipment & Supplies
Canon pixma mx700 error code 6A80 how to reset
  • 32 Answers
SOURCE: error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
Posted on May 28, 2009
komguy
  • 2306 Answers
SOURCE: Service Error 6A80
That error says there is something jammed in either the purge assembly or the sheet feeder on the back not able to turn. The purge assembly is on the right where the printhead parks for cleaning.
Posted on Oct 29, 2009
cene765
  • 787 Answers
SOURCE: How do I re-set error 6A80?
6A80 is APP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Check the sheet feeder.If this not help your printer need service.
Posted on Nov 02, 2009
  • 8 Answers
SOURCE: Error Code 6A80 on the Canon MX700
Supply Guy,
Here is the solution.
I am going to describe 4 buttons on your printer. Then, I will tell you what to do with these buttons to resolve this error.
1. Look for the Black & White selection button (large white button w/ black diamond on it).
2. Look for small pink button (bottom left corner of your printer control panel).
3. Look for the OK button (big button in middle).
4. Look for the On/Off button (top left).
OK - here we go. With the printer turned off, do this:
1. Using four fingers, one on each of the four buttons, press them all and hold them down for 10 seconds.
2. Release the On/Off button - but keep holding the other 3.
3. After a few more seconds the printer will turn on. When it does this, you can release the other three buttons.
So, to summarize, you press all 4 buttons for 10 seconds, release the power button and wait for the printer to turn on. After it is on, let go the other 3.
Your error message should go away. If you don't hold the buttons all down simultaneously, the printer could go into Fax mode; just turn it off and try again.
Posted on Dec 29, 2009
komguy
  • 2306 Answers
SOURCE: I have a canon mx700 & have an error code 6A80 -need help
That error says there might be paper scraps stopping the purge assembly on the right where the printhead parks, or something fallen into the slot where paper goes stopping the paper feed assembly. You just have to inspect closely with a flashlight before taking to the shop.
Posted on Jan 05, 2010
My Canon MP520 has a 6A80 error and now the printer head is also stuck on the far right side.
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
Feb 03, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Error code 6A80, won't print after changing ink cartridge. printhead is all the way to left. Tried moving it manually and turning off and unplugging printer.
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Verdana"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 14pt; font-family: Verdana; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Issue: ERROR LCD: Error Code 6A80
Solution #1: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Solution #2: Removing paper jams MX700
See very detailed description at this link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#ServiceAndSupport
Jun 30, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How do I re-set error 6A80? on my Canon PIXMA MX700 lcd display?
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
My Canon Pixma Printer MX700 is near new and the screen is showing Error Code 6A80...and the alarm light is flashing.. Does anyone know what the problem is?
According to Canon there is a way to reset the printer.
Just go to this link and this should help.
http://fix-your-printer.blogspot.com/2009/06/error-code-6a80-on-canon-printers.html
If you need further assistace, please respond to this post and I will help you.
Thanks for using FixYa
asnowman
Service Error 6A80
Oct 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MX700 ERROR 6A80
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Error 6A80 – means “AP position error”- indicates that "an error occurred in the APP motor during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
Hope this helps
Aug 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 6A80
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannon Mx700 error code 6a80.
It is because of Purge unit can be damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
Nov 27, 2008 | Canon PIXMA MX700 All-In-One InkJet...
241 people viewed this question
old marine
old marine
