Question about Ovens
The element in the griller is falling down. Il ive in Chatswood Sydney . Who can fix it
  • 2,272 Answers
This is the list of repair center in Sydney:--- Nearest post office: West Chatswood Post Shop, 2 Help Street Chatswood NSW 2067
Book your service online or call Master Appliance Services on 02 9987 0988 today.
Astron Electronics2/62 Macquarie St, Liverpool NSW 2170, Australia(02) 9821 2190.--------------------Mobile Appliance repair centreParramatta Rd, Sydney NSW 2000, Australia1800 044 841 0421 859 227 (Mobile).----------------------------------Commercial Combined Catering28/28/98 Ourimbah Road, Sydney NSW 2088, Australia0433 718 083 (02) 9953 5044------------------------------Stove DoctorPO Box 94, West Ryde NSW 2114, Australia(02)9012 0992 (Fax) 0413 419 641 (Mobile)------------------------This are the repair centers.Hope this helps you.Thanks.
Posted on Aug 24, 2010
Oven clock has power but oven and griller do not work no pilot lights coming on when controls turned on
ive seen this happen before in a rental apartment , what it turned out to be was . ovens require two power inputs for all there functions to work , this is evidenced by the larger power breaker in the panel supplying it (double handle) well it seems in the case I saw this happen , the installer didn't have a breaker with that little cross over handle to tie the two breakers together , and one side was off !
Jan 14, 2016 | Ovens
Simpson evolution 804 oven element changed
possibly check continuity with power unplugged. that will give you an idea if switch is defective
Dec 24, 2017 | Ovens
Miele 310 oven griller works but not the oven. why?
Remember that some parts of a 240 volt stove require two live wires and most of the controls or elements being only 120 volts require just one live wire. Hence the double pole 40 amp breaker must have tripped but does not appear tripped. Just turn it off and back on to reset
Nov 17, 2013 | Miele Ovens
I have a westinghouse wall oven, and the griller is not working. Are they easy to repair or do I require the services of a technician. Many thanks bernie
While they aren't that difficult to repair if you know something about appliances and are somewhat handy, you do need a multimeter to check whether the switch is the problem or if it is the element, which means you will me working with 220V that could ruin your entire day if you make a mistake.
Jun 09, 2011 | Ovens
BLANCO Stove Not heating up
Resolved, I took the fan cover off and the round elementjust fell apart, so I'll get a new element and all should be OK.
Regadrsd,
john S.
Jun 18, 2009 | Stoves Ovens
Need heating element for old Hotpoint built-in oven
Midwest Appliance Parts
2601 West Diversey
Chicago, IL 60647
1-800-621-1932
- Toll Free
1-773-278-1300
- Local
Supply a wide range of hotpoint oven heating elements
Apr 11, 2009 | Ovens
Cant get griller door back on
If your prob has not been solved yet, try this solution.
In your browser bar type in youube.com
Then in the sesrch box type in fitting oven door hinge
Click on appropiate video and follow instuctions.
This should help.
Plz rate my solution.
Thanks.
Dec 22, 2008 | Ovens
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
What wire goes where for my Westinghouse Freestyle elements?
oven wiring has the same conventions as house wiring.
green = earth, outside coating
brown or white = one of core ends
black = the other end
Jul 13, 2008 | Ovens
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
