My canon have an errror .the error code is E000025-0001.Please i need help
  • 489 Answers
SOURCE: Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
Posted on May 28, 2009
  • 1126 Answers
SOURCE: E000733-0001
E733-0001 Error Code
E733 and machine locks up with progress bar at 98% on boot up?
I would refer this error to a qualified service Tech.
Deals with replacing DC controller, Main Controller and Boot Rom as a set. Also, mention of replacing the Switching Regulator PCB Assembly if the previous failed to resolve.
Posted on Jun 03, 2009
n25an
  • 622 Answers
SOURCE: Canon image runner 4570 in error code E000100-0001
Ok here is how to reset the error if that doesn't work... you really need to call a tech... you are going to need some serious work done on your copier... ok... here are the instructions
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
Posted on Dec 21, 2009
canontech
  • 1219 Answers
SOURCE: ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Posted on Apr 26, 2010
canontech
  • 1219 Answers
SOURCE: Canon iR 3100CN Error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Hope that helped!
Posted on Jul 25, 2010
How to solve E-540 error in canon ir 2016
You need to ask about this in the canon service centre. Please also mention what errror your camera is showing.
May 26, 2012 | Canon ImageRunner 2016 Copier
Canon irc3170 errror code 0020-01a8 how can i rectify?
this is error code for atr sensor's reading. Probably on sensor there is toner dust so he can't read the true value. It needs to be cleaned or replaced.
Call service.
Also this error can occure if the developing clutch is rotate constantly, so he is stiring out too much toner.
Aug 21, 2011 | Office Equipment & Supplies
Errror code 6000
Error code 6000 appears when the paper jam, power off the printer and remove carefully the jam paper and power on the printer:
Nov 09, 2010 | Canon Pixma MP450 All-In-One InkJet...
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Printer reads error
Hi
Hope you come back for this
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 11, 2009 | Canon MP830 All-In-One Printer
Pixma error code 6A00
Dear luis,
Your printer has paper feed related error. There are 2 possibilities of this errror: Auto sheet feeder or logic board faulty. Then you need to replace these parts.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
PIXMA iP8500
Error 5100 on Canon Pixma iP8500. flashes orange 2 times. Sounds like the paper isn't being picked up. But I don't know how to fix it.
Jan 03, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
104 people viewed this question
k24674
