Question about Motorola Mobility RAZR V3
No display my phone fell down yesterday and it has lost its display. It turns on but no lcd display--all black. what shall i do?
    Novelist:
  • 124 Answers
Hi frn,
I m sure that the LCD display chip/plate is damaged inside.
I recommend u to go to mobile technician and change the LCD chip/plate and ur problem is sure to be solved.
Send me a feedback. Sajan
I will help u in other problems also later. Just send me feedback.
Posted on May 05, 2008
My samsung s3500 fell down on the ground and when i tries to turn it on the lsc was black. at first i tought that it's the flat cable so i changed it. but the problem is still here
if you changed the flex cable already and the problem is still the same I think the LCD of your phone is damaged... Try to make a call even the LCD of your phone is black... if you can make a call... REPLACE LCD... this is it...
Feb 02, 2011 | Samsung S3500 Cell Phone
My handset fell down yesterday and the display is gone.Though I can receive and make calls
Hello
When the handset fell down, the flex that connect the screen and the panel has shift. Get a screw driver, unscrew the phone and try to adjust the screen.
If after doing his the problem continues you need to change the screen of the phone.
Thanks
Aug 12, 2010 | Nokia 6300 Cellular Phone
Screen cracked and turned black, unable to use desk top the glass that you touch on top of the lcd screen is not cracked,its the bit underneath.
To help you with this problem, I want you to know that when a cellphone got fell or something done to phone,like you accidentally sit on it, the main problem will be make is lost in display or it will crack,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD display connection is only misaligned or need to be replaced when it was crack. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem.
Don't forget to rate this solution please..Thanks..:-)
Oct 31, 2009 | Motorola Mobility A1000 Cellular Phone
Laptop fell off moving vehicle and now the screen wont display anything, but the laptop will turn on and act normal?
You should contact the manufacturer. The laptop is broken. Make sure you don't tell them it fell from a moving vehicle.. Probably not the best way to start or end that conversation. I'd go with... "It worked yesterday, but today the LCD wont display anything".. You're not lying. Either way if it's under warranty you're more likely to have it fixed. Otherwise, the LCD replacement is almost always more costly than simply replacing the laptop. Best of luck!
Oct 19, 2009 | HP Compaq Presario V2403NR Notebook
My phone's screen turn black
Hi, Now ur cell fell down thats mean flat cable from the MB to the lcd is damaged pls get it changed if there's no change now change the lcd .
good luck
bye
Sep 04, 2009 | HTC G1
My Nokia N70 lost display suddenly yesterday,
Just change the LCD.........it will work
May 02, 2009 | Nokia N70 Cellular Phone
Phone fell and the screen is black
dis assemble including lcd then assemble in 1 hour
Mar 02, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Sony 200i fell down and now its display is not working properly.
THIS TYPE PROBLEM IS A EASY CASE THE LCD THAT U SAID IS NOT WOKING WELL REMOVE IT AND PUT ANOTHER ONE.
Nov 17, 2008 | Sony Ericsson W200i Cellular Phone
O2 XDA II mini fell down
your unit experienced shock. due to fragility of the phone, your LCD might be broken, if not, the LCD connector needs to be refitted to its slot. If the problem is still the same, you need to replace ur LCD.
Oct 25, 2007 | O2 Xda II mini
Motorola Mobility RAZR V3 Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
