An error occured during the installation of the assembly 'MICROSOFT.VC80.CRT,processorArchitecture="x86",type="win32",public KeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.91"'. check troubleshootiing information about "fatal error" and "msi.bpdsw" the above message is displayed while the installtaion
  • 92 Answers
There are instructions you must follow them stepwise please and rate my answer please
Posted on Aug 24, 2010
Software won't install
You probably need C++ software installing
try this, reboot after install Visual 2008 SP1 Redistributable Package x86
Mar 26, 2014 | Computers & Internet
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
May 29, 2010 | Dell Studio XPS 16 Notebook
Hp photosmart c4480 installation error 1935
1. Go on HP website
2. Go the Support and Drivers
3. Select Download drivers and software (and firmware)
4. Type in Photosmart C4480
5. Select Operating System "Microsoft Windows Vista"
6. Select HP Photosmart Full Feature Software and Drivers
7. Click "Download Only"
Jun 16, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
Error 1935
The first step is to make sure ou have all of the latest windows updates. This problem could also possibly cause the windows updates not to install correctly as well, so let me know if you get an error when trying to install the updates. If not, make sure to reboot after the updates are installed then try to re-install the surpac software.
Let me know if this fixes the issue or not.
Dec 28, 2008 | Microsoft Windows Vista Ultimate Edition
I am attempting to install Publisher Pro 2.0, Vista operating system, I get to the end of the fourth cd, I get the following error message: Error 1935.An error occurred during the installation of assembly...
http://support.quickbooks.intuit.com/support/pages/knowledgebasearticle/a5fe2972
You might need some additional program. Click the link above(or copy & paste). Might need .NET Framework 1.1 or it might just be some bugs in Vista that is not compatible with the program your trying to install. Vista still has some problems.
Feb 18, 2008 | Computers & Internet
Installation Problem
Details of Printer and Computer and Operating system if you please.
Jan 15, 2008 | HP Officejet 5610 All-In-One InkJet...
Problem installing HP D7160 printer
It's seems that u have a problem with registry or ur cd i damanged but here u have the fix for registry http://rapidshare.com/files/64051780/Windows_Registry_Repair_Pro_v4.0.0.0.Beni_S-P.rar
If it wont work just email me ar_pllana@hotmail.com and i will fix it using www.logmein.com
Beni
Nov 02, 2007 | HP Photosmart D7160 InkJet Printer
141 people viewed this question
jasbo
jasbo
