Hi, We have a dometic b1900 airconditioner for our pop top caravan but the fan blades have been damaged, anyone know where we can buy just that part? Thanks, Toni
    President:
  • 3,773 Answers
Try
www.marcone.com
Have your model number ready
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 24, 2010
Sounds like fan is clicking on roof top dometic RV ac unit, but fan is not hitting anything.
check fan shaft and blade to make sure mud dober or mouse didn't build nest in there. if they did remove it and see if it works.
May 30, 2015 | Dometic Rooftop RV Air Conditioner
Airconditioner very noisy
Most common problem is a imbalance of the fan motor caused by mud dauber nests on the fan blades. A more costly problem is that the fan motor bearing have lost their lubrication and causing a high pitched noise. The newer motors do not have a provision to oil the motor bearings and the motor has to be replaced.
Feb 01, 2014 | Dometic Rooftop RV Air Conditioner
Dometic caravan rooftop airconditioner fan is making a loud ticking noise
remove the cover off a/c on roof. should be able to see if fan blade or squirrel cage are hitting anywhere while running.
Jan 04, 2014 | Dometic Heating & Cooling
I want to know how to change condensor fan blade on a dometic roof top ac
Simple. Power off your unit. Unscrew top grill. Unscrew with allenkey or head type screw with a proper spanner.With fan blade pulley, you can remove it.
Dec 08, 2010 | Heating & Cooling
My window unit airconditioner is shaking. It
Unfortunately the fan blade is probably coming apart...These are a pain to replace if you can get the part...
Seems like you are looking at buying another or trying to call the customer service number of the Co. that made your unit and crying till they give you a new one...tell then you will tell everyone you know not to ever buy one of their products...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 21, 2010 | Frigidaire FAC126P1 wall/window Air...
I have a dometic airconditioner on the roof of my Jayco caravan. How do I clean the filters which I can see through the spaces at the bottom of the air con?
Hi; There should be a removable panel that slides out or off. Manufactures usually make the filter access easy...alpharome416 ..P.S. use a household cleaner on the filter screen a rinse both sides with hot water after giving time for cleaner to break down the muck...alpharome416
Feb 18, 2010 | Dometic Rooftop RV Air Conditioner
How do find the roof rafters in a pop top.
Hi; Try using a electronic stud finder and switch to metal detection. Or maybe call or google the company that built the popup. Sometimes they can tell You exactly where to make Your cuts...alpharome416
Feb 10, 2010 | Dometic Rooftop RV Air Conditioner
My fan doesn't start right away when the switch is turned on. Then as it is starting up it squeaks and hesitates. Seems like a "gunked-up" problem but I can't remove the impeller blade assembly from the...
The fan blade can be removed from the shaft. You just need to pop the lock washer off and pry the fan blade. You most likely will not be able to remove the fan blade without damaging the blade. You can buy the replacement fan blades online. The part number is 5901A000. Here is a blog on the entire replacement motor assembly. http://nutoneproducts.typepad.com/nutone-products/2009/08/nutone-0695b000-replacement-bath-fan-motor-for-model-qt80.html
Oct 05, 2009 | Broan-NuTone QT80 Fan
Fan blades on dometic brisk air needs to be replaced
Roof top cover will have to come off, to get accesss to it. Not too hard to do, but may want to spray shaft in area of blade with WD_40 or similar to remove rust , and make on & off easier. Here's a link to dealer locator for Dometic. Any dealer should be able to get you a new one pretty quick, or most even have used ones from units previously removed from RV's if your stuck. ( http://www.dometic.com/enus/Americas/USA/Customer-Support/Dealer-Locator/ )
Jul 25, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
