Hello, We have acquired a Servis Caress M2010 tumble dryer, which keeps tripping the house fuses. The noise filter is blown but no obvious other faults, any ideas?
  • 7 Answers
SOURCE: servis 1200A caress washing machine trips electric
A wiring harness may be loose and the vibration has worn through the insulation. Put it on the side and take a look for loose wires and rubbing.
Posted on Mar 08, 2008
SOURCE: TUMBLE DRYER
My tumble drter has stopped turning
Posted on May 23, 2008
astruttman
  • 45 Answers
SOURCE: dryer blows house fuse --keeps tumbling--no heat
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
Now, if your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. You have to remove the entire front panel on some models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
Posted on Jan 11, 2009
  • 2920 Answers
SOURCE: My dryer tumbles but doesn't heat.
it sounds like to me that the heating element or the limit switches are out on the dryer
Posted on Jan 19, 2009
  • 100 Answers
SOURCE: hotpoint wd440 washer dryer fault
sounds like the heating element of the dryer may have come loose and is shorting against the metal dryer box on top of the drum.
engineer job if you're not electrical
Posted on Jan 27, 2009
Dryer portion on my stackable does not heat up.
Hello there:
please try these solutions and keep me informed on how this is going for you ok
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Kenmore 88752 Top Load Stacked Washer /...
No heat
Hello there:
There's no heat If your dryer doesn't heat, check these: Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block
May 13, 2010 | Amana DLE330RAW Electric Dryer
I am not getting any heat to dry clothes what is causing this?
Hello there:
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 15, 2010 | Kenmore Dryers
Does not heat I have cleared the vents and filter
if your dryer doesn't heat, check these:----
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 11, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Hello, my maytag neptune dryer runs, but will not dry. where do i find the serial # ?
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. serial # should be inside door jamb!
Jan 01, 2010 | Maytag Dryers
Kenmore heavy duty. its working properly but not heat
Power from the house:
Heating element:
Thermal fuse:
Wiring : A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
thanks and keep updated.
Jul 08, 2009 | Kenmore Dryers
My dryer will not tumble nor will it heat, we have replaced the thermador sensor but will not run. lights flash and can hear a clicking noise, sounds like a relay of somekind going on and off. Any...
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Nov 20, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
It has no heat
Heating element
Thermal fuse
Wiring
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 18, 2008 | Dryers
Broken heater during the dryer cycle
Heating element
Thermal fuse
Wiring
Feb 17, 2008 | Equator EZ 3710 CEE / W Ventless...
No heat
Heating element
Thermal fuse
Wiring
Jan 28, 2008 | Whirlpool LGR5634L Gas Dryer
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
