Question about Bauer Premium Fly Reels Bauer Compressor Scuba Fill Hose W Gauge
Wiring diagram for air compressor bauer poseidon edition
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
I have a 1998 Foed Explorer Eddie Bauer Edition, I've recharged the ac (store bought) but still there's no cold air. What else could be the problem?
you need to put gauges on it and see what the pressures are to see if the compressor is working while your waiting for that is the compressor running? is the large ac pipe cold?is the smaller pipe hot?
Jul 06, 2012 | Cars & Trucks
Hi, looking for the air compressor on my 99 Expedition Eddie Bauer edition. One dealer tells me it's under the hood, another says it under the car by the rearend... can you tell me? Need to test it...
normally , they are on the engine on the right side, start from the firewall on the right side , you will see 2 hoses coming from the a/c system that is connected at the firewall, 1 of them is larger than the other, they both go to the air conditioner compressor, but don't get these 2 mixed up with heater hoses, because these 2 go to the engine, and water pump.
Jun 20, 2011 | 1999 Ford Expedition
Instruction manual for poseidon jet stream regulator
Manual:
http://www.frogkick.dk/manuals/poseidon/1999/
Service manual for all poseidon regulators (trained scuba technicians only):
http://www.frogkick.dk/manuals/poseidon/2003/manual.pdf
May 31, 2010 | Poseidon Odin/Jetstream Regulator
Jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Mar 15, 2010 | JBL BP1200.1 Car Audio Amplifier
Bauer Premium Fly Reels Bauer Compressor Scuba Fill Hose W Gauge Logo
510 people viewed this question
Top Bauer Premium Fly Reels Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Bauer Premium Fly Reels Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
