Question about Sanyo DS27510 27" TV
Hooking up digital satellite system to sanyo 27'
I hooked up the box to the tv, tv is on..no power on the box but it feels warm...I do not have a remote for the box..do I need a seperate remote?
  • 78 Answers
If you can't operate the receiver from the front then there is something wrong with it. you need to get it repaired or replaced.
Posted on May 05, 2008
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
I have a 2002 Sanyo tv what do i need to make it work with out the cable company
do you mean you want to use the tv not through cable program?. ok just remove the cable box then hooked up an air antenna to the RF tuner. then change the settings in the tv select air not cable.
Jul 27, 2012 | Sanyo DS27510 27" TV
We have a Sanyo CE32DFN2-B digital television. Our region has completed the digital switchover today and now we cannot tune the TV into any channels at all. Is this because our TV is too old to cope with...
Ur tv have a big back like hunt back creature?Yes?This tv it is not a Digital tv.It is an old CRT tv-tube analogue design tv.This tv still will work and have a broadcasting incomming signal if it is hook up to a pay services tv like Satalites tv like Direct Tv,Dish Network tv,Timewarner or Cox Cables services and ATT U verise or Verizon Fio digital hook up.If u wanted to watch a switch over FREE OVER THE AIR DIGITAL incomming broadcasting signal for this tv it will not work alone,the tv must have be to hook up to a BOX that call a DIGITAL CONVERTER BOX than this tv will work for a FREE OVER THE AIR DIGITAL broadcasting tv channels stantions.This DIGITAL CONVERTER BOX are no longer on sale on regular Stores.Tries websites like Amazon.com,Ebay.com will able to buy these BOXES so call DIGITAL CONVERTER BOX.
Aug 17, 2011 | Sanyo Televison & Video
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
Unusable signal
Usually need a second receiver. Cannot just split signal. With some cable providers you can split the cable before it hits the cable box for basic cable channels.
Suggest contacting Cable Company if does not work.
Thanks!
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
Digital signal conversion
If you have cable TV, satellite TV, or FIOS, the coupon eligible converter boxes aren't needed and aren't useful with those services.
They gov't coupon converter boxes are only good for reception with a regular TV antenna or rabbit ears.
According to the specs on epinions.com, no, this TV does not have a digital tuner. So, if you use a rooftop TV antenna (not satellite dish) or an indoor TV antenna, you WILL need an ATSC to NTSC converter box. You need not wait until next year, however, as most U.S. TV stations are also broadcasting digital (ATSC) now.
Feb 23, 2008 | Sanyo DS27820 27" TV
Magnavox hdtv
The Magnavox 27MS343S is a standard analog 27" TV. It is not high definition and therefore cannot generate a posterized or pixelated picture. I will bet you are using a digital cable box or satellite reveiver and the problem is in that box, not the TV. Hook up a regular VCR to the TV, set the TV to channel 3, put in a good pre-recorded tape and hit PLAY. If the tape plays nice and clear on the TV, the problem is in your digital box.
Sep 07, 2007 | Philips Magnavox 27MS343S 27" TV
Sanyo DS27510 27" TV Logo
54 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
