Question about Samsung HCL4715W 47" Rear Projection Television
Power problem i recently moved my tv, and it won't start now...
Don't move it.
Posted on Jun 19, 2008
Where do I find the part number on the power board for my LG 47LH40
You have to contact the authorized service centre for LG, to get an original replacement.
Jun 28, 2013 | LG Televison & Video
It doesn't turn on
follow this steps and fix it. God bless you
Mar 24, 2013 | Sportsart Fitness TR32 Treadmill
TV clicks but won't come on .
Check for bad capacitors in the power supply section. Sites like www.TvRepairKits.com have power supply repair kits if needed,
Mar 22, 2012 | LG 52SX4D 52" HDTV
I HAVE A 1995 MITSUBISHI GALANT VR-6 IN THE PHILIPPINES. ONE PROBLEM THAT CAME UP RECENTLY WAS WHEN I DRIVE IT AND ACCELERATE TO MOVE FROM 1ST TO 2ND GEAR, AS I STEP ON THE GAS PEDAL, I WON'T GET ANY...
Your Have to check your clutch lining it might be worn out. Your have to call mechanic to do this job because he will put down the entire transmission to replace that parts. This Problem Call Clutch Sliding.
Aug 13, 2011 | 1995 Mitsubishi Galant
Remote won`t operate tv stuck on channel 99 w/ no signal showing
Some units have a little hole where you can insert a straightened paper clip and manually retract the DVD.
Make sure the power is turned off first.
"Your mileage may vary."
Jun 30, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
RCA projection, no power, no sound. recently moved.
Ur DM power board have burn capacitors,check for puff up capacitors,and replace it.Tries these websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dell plasma 42 inch
fot the most part, you have solved your problem (pow bd), The main bd may also need to be replaced as well. The is a signal upon powering up the system. the pow bd communicates with the signal board. The signal bd, also is responsible for ALL of your additional I/O lines. Between the two of these, + a firmware update, i think the tv will be just fine.
Feb 03, 2009 | Dell W4201C 42 in. Plasma HDTV
I recently moved my toshiba 62mx195 across country it was well wrapped in bubble wrap and moving blankets, Now we go to turn it on and nuthinghappens except the timer/rec blinks yellow then the power blue...
Your Tv power supply is in protection, this means it wont start up, could be static. Rather take this to a Service Centre to check, If you have insurance claim it under the section travel/moving goods etc
Dec 05, 2008 | Toshiba 62MX195 62" HDTV
Power
the tv probably has a loose solder joint or broken or cracked circuit board due to moving
Aug 13, 2008 | Mitsubishi VS-55707 TV
Sony Trinitron color TV model no. kv-27v22
dear, you can check that transformers out put before connecting to a tv. also when its connected to a tv.
get a avo meter and connect in series with a tv.
observe the current on the intial switch on and when the picture goes. if you notice that current on intial switching is high and then it starts going lower and lower, then change the transformer.
but if the current starts going up from the intial current then check the power supply components of the tv.
thanks for asking fixya.
Mar 02, 2008 | Sony KV-27V22 TV
Samsung HCL4715W 47" Rear Projection Television Logo
26 people viewed this question
Henry  Thomas
Henry Thomas
