Question about Logitech 967437-0403 Keyboard
Hi. I need to find out how to use the insert key. I need this this as it is used quite a lot in the 3d Apllication which I currently use. Upon the button the are two functions, one has a arrow in a box with Scroll Lk at the side below this is insert, when i prees this nothing happens. So can you tell me what manner of keys do press to get the insert working. Thanks
  • 724 Answers
Open a word processor
get some text i n there
Block copy and paste
or hold the shiftkey down and use the right or left arrow curse to block
Hold down the shift ke amd delethold down the shift key and insert
Posted on Aug 24, 2010
Where should i get best colour 3D printers?
Now-a-days everybody using 3D printers for their printing work.I think 3D printer is best for printing.If you want to get best 3D colour printer then search it from any computer accessories market.If you want a best 3D printer from online then i can suggest you one which is selling best 3D printer and parts.Here Shop Easy 3D Printing
Apr 21, 2016 | Office Equipment & Supplies
Where should i get best 3D printer colour ink?
3D printer is a kind of best printer category now.A printer can print colour page too.you are telling about colour ink for 3D printers.Now-a-days colour ink are available any accesories market but its rare to get a best quality 3D printer ink.I am able to help you get 3D printer ink from online.Here is a online shop which is selling 3D printer parts,ink,and many more. Shop Easy 3D Printing
Yet another Ford Focus Key Fob problem...
You need the dealer on this.
Oct 24, 2012 | Cars & Trucks
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
Ulead Cool 3D V3 will not work with Vista
windows ten is free and can be loaded onto a flash drive and you can use this to install. Your programs might not be met be your system specifications. Try install or upgrade computer.
Apr 08, 2017 | Ulead COOL 3D 3.0 Upgrade Version for PC
Car won't start after sitting parked for over a year
hi! there,
even how new your battery was, there some other component cars have in starting your car,battery is just one factor
the ignition system need to check for proper maintenance.since most of them now are elctronically system.this where starting came when you turn your key the current flow mostly in ignition system until your spark plug ignite and produce combustion upon cranking your engine if all are in full condition your engine run,in your case ther are some faulty part and wiring needed to check.
try to clean your ignition coil some impurities block current flow.
check your ignition module most terminals acid may jump current flowing,check all cables that connect distributor to spark plug replace faulty cable,spurk plug clean contact point of spark plug if necessary replace,tighten connection of your starter motor couple to your fly wheel maybe theres a loosen connection,internally spark plug becoming wet had hard the current flow due to leak on rocker arm valve seat,oil is leaking check this out,if all are quite ok
star your engine.regards and have a nice day
Apr 01, 2009 | 1998 Pontiac Grand Am
Rear hatch wont open
Spray WD-40 or similar lube in key slot, using red tube from can & insert it as far in the key slot as you can, and spray it often & lots, it may take quite a few times, or it may not release at all, but keep working the key in & out and try to turn as well as keep trying your power lock & remote. Get as much spray as you can up inside the handle area too especially at both ends. It's a hit & miss but you may get lucky. If you do get it open, you need to remove the inside panel & get to all the linkages, especially pivot points & spray them down good to unseize them, then after, coat them well with white lithium grease.
Jan 07, 2009 | 1999 Plymouth Grand Voyager
Gateway 1150 won't boot to CD upon pressing Esc key.
hmmm...unfortunately that is now a primary function key...
you can press F2, enter bios set up and make cd first boot option(follow instructions)..
then insert recovery cd, and restart system..
Nov 23, 2008 | Gateway 2520796 Keyboard
Classic Navionics chip in a Furuno 1833C
Gold Navionics is really not bad at all, but by todays standards, lousy. This is a VX1 unit and the classic cartography is frowned upon now, but in the day, this was quite good. So you have to ask, is it worth replacing for cartography alone? Radar and Sonar will plug and play to an 1834C, which is available with C Map or Navionics. Furuno 3D, on the other hand, uses the hyper cool Map Media 3D cartography with sat images and all that, plus other cartography too.
Aug 31, 2008 | Navionics CLASSIC MMC US835L SOUTH FLORIDA
Logitech 967437-0403 Keyboard Logo
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
