Question about IBM ThinkPad T41 Notebook
Os does not loads and if load it is geting struck ,i think battery kit is use
    President:
  • 2,291 Answers
Try with adapter, put out the battery for some time and then check , formate ur drive and reinstal the os
Posted on Aug 24, 2010
In fifa 07 game , it strucks while playing ....it runs slowly by strucking ..in my pc ............how to solve this problem...?
From your problem it sounds like your computer does not meet the minimum requirements to the game. And that is why your computer gets the load when the game gets on.
It could be your CPU Ram, speed or Graphics card.
Mar 29, 2012 | Video Game Consoles & Games
2003 buick wont start
put a load test on the battery. the battery could have 12 volts until a load is put on it then it looses voltage fast. have the battery tested not just checking how many volts it has,also check the ground to engine and power to fuse box in engine compartment. ive seen these cars melt the connection that runs from the battery to fuse/relay box, the where the connection connects to the fuse box you may find the bad connection there but first have battery tested.
Jul 09, 2010 | 2003 Buick Century
My laptop won't hold on battery after loading OS
Well the battery isnt holding the charge so you need a replacement it happens if there on the shelf for a year or more thats wy you buy direct
Apr 26, 2010 | Toshiba Satellite A105-S4284 Notebook
Hi, my system not working properly.
I don't think this is a BIOS problem. Sound more like you need to re-load windows and start from scratch. Make sure your USB is turned on in the BIOS.
Dec 25, 2009 | ASUS M2N-MX Motherboard
Not geting a charge back 2 my batterie
Hi and welcome to FixYa,
No charge to the battery could be caused by:
  • faulty / loose / corroded / burned terminals / connectors from stator to regulator (most likely);
  • faulty rectifier / regulator combo (likely);
  • faulty stator (least likely).
To determine which, initially visually inspect the wiring and its connectors from the stator to the rectifier/regulator combo. Thereafter, a DVM/VOM is required to measure the AC voltage output of the stator (~30VAC), the DC voltage output of the regulator (~14.5VDC @ 4000RPM) and engine off battery voltage of ~12.5VDC. It maybe to your advantage to have the battery load tested as well.
Good luck and thank you for asking FixYa.
Nov 08, 2009 | 1996 Yamaha YZF 600 R thunder cat
Dst SHORT KEEP GETING THE BLUE SCREEN SO I RAN DELL TEST THAT SAID DST SHORT ?? I DO NOT HAVE ORGINAL OS DISK & UNABLE TO MAKE A COPY ERROR WITH DOWN LOAD??
DST = Drive Short Test.
Its called 90/90 Diags for hard drive. You need to contact Dell Tech because the hard drive needs to be replaced
Jun 05, 2009 | Dell Inspiron 6000 Notebook
VISTA Strucks in the loading tab
U are facing the problem because may be your OS is not able to load all the drivers needed for the normal mode.
Don't install your OS from the where u r installing till now. Use some other DVDs or IMages to Install the OS. If it works fien than u can ask for a change because it seems that the image u r using is corrupt.
-Arualld
Apr 23, 2009 | Microsoft Windows Vista Ultimate Edition
Yahoo downloading messenger
please check whether system detects any virus. If you face the .dll problem again try to reboot your OS. This may solve your problem.
Nov 20, 2007 | Computers & Internet
Optiplex Gx110 Freezing on Bios Post
The only thing I can think of is there should be a jumper pin that on the mother board that resets the cmos. Unplugging the battery does not clear the cmos rom. My guess would be the cmos rom is currupted and unfortunatly you need the rom loaded before you can flash and replace it. My advice is ditch it.
Aug 02, 2007 | Dell OptiPlex GX110 PC Desktop
IBM ThinkPad T41 Notebook Logo
19 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
