Question about Baumatic 23 in. BDW3 Built-in Dishwasher
I have Baumatic BDW 3W Dishwasher The programming controller stops rotating automatically at certain points in the revolution. can you advise please.
I have Baumatic BDW 2W Dishwasher The programming controller stops rotating after the first normal cycle revolution. can you advise please.
Posted on Dec 03, 2010
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
Baumatic BD1631 dishwasher isn't washing the top tray. The rotating sprays are clear and hoses appear ok. The 'salt needed' warning light is on even though I've filled it with salt. Any ideas?
Try rotating the arm manually. Check whether its freely rotating. Clean the rotating axis area.
Check whether the pressure reaching the top spray arm hose.
May 21, 2010 | Dishwashers
Right hand side nylon spring cord guide broken when cord snapped and now door return has no tension.
Searched for a nylon rope guide for a Baumatic BDW 9 but was unable to locate one. I found that many of the components for the BDW 9 also fitted the BDW 10. So I searched for the rope guide for a BDW 10 and found the correct product. Problem solved!
Nov 15, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
Our BDW 13 keeps tripping our fuse board
your cicuit is overloaded. hook the DW up to its own cicuit, or at least one that will not overload it. Circuits should not be loaded to more than 80% of their capacity. 15 Amp load no more than 12 amp.
when motors/pumps start they use the most load or power, or when your DW turns on the heat.
Nov 01, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Need door locks for bdw 10 and bdwa where can i get these
You will have to look in ypur local yellow pages or phone directory, and try to find a appliance parts warehouse. They will have or can order what you need.
Oct 02, 2009 | Baumatic 23 in. BDW10 Built-in Dishwasher
Looking for reset switch
If your getting `E3` then it cannot be reset, one of the two thermostats on the heater element cannot be reset and has to be replaced, around £18, you can test which one of the thermostats is faulty by using an `ohms` tester, open circuit, faulty, this is a very common problem with these.
Sep 08, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error E1 comes up on dishwasher
E1 error comes up when faucet is not opened. this is shown up when it takes longer filling time.
The solution for this is to ensure that the inlet hose is not kinked or crushed.
Dec 23, 2008 | Baumatic 23 in. BDW10 Built-in Dishwasher
High pitched whining noise from bottom of dishwasher
the arms are only turned by water coming out of them thro angled jets, they are not electrically driven. the noise will be coming from the circulating pump, probably one of the bearings. no cure except to replace
Mar 10, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Baumatic 23 in. BDW3 Built-in Dishwasher Logo
159 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
