Question about Dell Latitude D531 Notebook
Hi, I have a dell latitude d531 laptop, and today i pulled it out and plugged in the power adapter and pressed the on switch and nothing-not a flicker, no BIOS, not one led flashed. totally dead...i noticed that the green power light on the adapter went out every time upon contact with the laptop input plug. And, the battery pack dead...i did unplug the rech. batt pack and tried plugging in the adapter without the battery installed; same result.How should i proceed to TS/fix what seems to be a power problem with the laptop? any help much appreciated.....JM
    Master:
  • Dell Master
  • 246 Answers
Call Dell customer Support Number 1-800-204-4427 if your dell laptop, computer, printer and tablet facing technical problems. Our dell technical support experts will help you out within no time.
Dell Technical Support Phone Number 1 800 204 4427 USA Canada
Posted on May 01, 2017
Kegtapper
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
Pyrhyc
  • 2028 Answers
SOURCE: laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Posted on Jul 15, 2008
  • 998 Answers
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
  • 479 Answers
SOURCE: Dell Latitude D430 laptop. Laptop
the issue seems with the inverter board of the machine and chek once the machine at any other place.
Posted on Jan 29, 2009
zohail
  • 1223 Answers
SOURCE: Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Posted on Mar 07, 2009
My name is Adrian I have a Dell Latitude D531. I was burning a video to a disk then my screen went black/grey, i waited five mins but still no response. So i turned the laptop off and when i turned it back...
metod 1, remove battery from pc, after 10-15 minute put, and turn on pc.
If will not be resault, you need reinstall operating system, but how i understand , your pc have problem with ramdrive, /wheh you are burning the disk, it working with this logic, writing it in your ram drive, from it on disck/.
Jun 01, 2011 | Dell Latitude D531 Laptop Motherboard ...
Which web cam driver should i use for a latitude d531 laptop?
hi.
web cam driver is auto install once your installation of windows O.S.
u just need to install webcam software on your laptop.
regards
Feb 12, 2011 | Dell Latitude D531 Laptop Computer PC...
Where can I download screen resolution drivers for a latitude d531?
Go to www.dell.com and check for driver downloads, the upgrade your after should be listed under video. Make sure you enter your model number and the operational system you are using, list that it is a Dell Latitude D531 and it should take you to a list drivers available for your model.
Dec 22, 2010 | Dell Latitude D531 Laptop Computer PC...
I cant connect my dell latitude d531 to the internet
Press the button just to the left of the power button (when mine turns on the bluetooth light appears just below the screen on the right side). See if it works now. If not, reboot, press the F2 key during startup (keep tapping until the message in the upper right goes to "Preparing to enter setup") to go into Setup. Go to the bottom of the list on the left side to Wireless. Hit enter to open the list, go down to Internal Wi-Fi and make sure it is enabled on the right side of the screen. Also, check the last setting and set LAN/Wi-Fi Auto Switch to Off. You might also have a bad wireless card or a bad driver. If nothing works then re-post as possible driver problem.
Apr 26, 2010 | Dell Latitude D531 Laptop Computer PC...
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Latitude won't switch on
hello, you will need to check the memory of your system if they are not bad. and i will also like to know if the system is making sound when you power it on.
Aug 12, 2009 | Dell Latitude D531 Notebook
Power supply goes off on a dell D531
Problem is the powersupply of your portable w/c is integrated to the motherboard. If it is still under warranty, call dell tech support they will replace the motherboard for this issue.
Jun 10, 2009 | Dell Latitude D531 Notebook
Dell Latitude D531 Notebook Logo
156 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
