Question about Inverter KEB COMBIVERT F5
Hallo i got a problem on the f5 drive it give's me a E br fault can you help me
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • Inverter Expert
  • 120 Answers
The brake control functionality of the inverter is being used.
Possible problem with your brake or load that is triggering this error.
Posted on Dec 06, 2013
2005 Subaru Legacy 198K miles intermittent stalling starts to idle rough. Putting it in neutral and giving gas will keep it from stalling. The check engine doesn't come on and there aren't any faults.
something that wont throw a fault code
i am thinking coil and plugs
even fuel pump relay or bad fuel
engine bay picture removed
2005 subaru legacy
is yours the turbo motor .. could be turbo related5d3dd8f7-1c47-4e37-aef4-64d2eb37db4f.jpg
Apr 16, 2017 | Subaru Cars & Trucks
My 99 tacoma starting chugging, ideling down in neutral, shaking while driving and check engine light flashing all within 5 mins. Suddenly a couple days ago. Havent driven it since. Help
with engine light on
the ECU has fault codes to be read
its either fuel delivery or spark related
too many sensors fitted on these trucks
.. to be able to guess
Jan 25, 2017 | Cars & Trucks
My 2007 chevy z71 4x4 auto trans is shifting from drive to neutral, while I'm driving, what can be the problem?
at one speed in particular
or revs out when popping back to neutral
or not holding first and second
if not a shift linkage fault
or broken engine mounts
shifting by itself= internal fault in the transmission or transfer case
low on oil
overdrive band
low oil pressure
worn discs
solenoids
torque converter failing
Nov 10, 2016 | Cars & Trucks
Engine warning light comes on dash board ,loss of automatic but car still drives ok fault clears until you select reverse
Hello Tim Aldred
Without the year, make model ... it is quite difficult to give any advice...
If you only want GENERAL/TYPICAL... Get a OBD reader
and find out what your car is registering as issues...
Combined with the activity you are performing, service history (typically: lack thereof)... One can then begin to postulate.
Good luck... Happy hunting!!
Technical service bulletins:
BBB Industries Premium Alternators Starters Power Steering Products
May 22, 2016 | Cars & Trucks
How do i cure fault
ah double posted.... and shorter
what DTC code, do not fail to list all DTC codes
using a real scan tool that shows them all,
includinng all P1 P2 codes. factory only codes
is the transmissing slipping when flogged up hills
is it missing gears,
or other harsh shifting etc.
we cant drive it so how can anyone here, diagnose the most complex thing on car.
how?
if in USA we cant guess that either
if in uSA go to any ASE rated shop.
ask them to diagnose it.
or any pro Autotranny shop and same.
fixing a/T in a text box is near impossible see?
and no list if DTC stated. now that is over the top.
what fault.
no symptoms stated, we cant guess that or drive car.
we are totally blind here.....
no car stated
no year stated
no gear count?> either (tells helper which A./T you have)
Jul 20, 2015 | Isuzu Cars & Trucks
When i try to run power point from toshiba satellite pro (to sony projector) I get frequency out of range. IT geek man has had it working in ffice by switching projector on first then lap top, but I cant...
are you using vga out on notebook ?
are you using vga in on projector ?
Turn on projector
hold down function key on notebook when turned on - FN button and press F5 - cycle through each mode by releasing f5 and pressing F5 again till you get CRT or CRT + LCD (while keeping FN pressed )
on data projector input source should be computer or vga
Jul 07, 2017 | Toshiba Satellite Pro L300 Notebook
21/10/09 Hallo. Re.: hp Omnibook XE2. Upgrade hard disk drive 20 GB or 30 Gb. I would like to know if some one has installed a 20 GB or 32GB hdd and if he has any problems with that. I would like also to...
the HDD best to use is an SSD.
the HDD was a standard, 2.5? PATA drive for laptops
why would you want such a small drive, they dont make them now. (40 smallest?) new.
this PC is not supported by HP now, its too old a Pentium III no less.
why would 20gb be and upgrade.?? 10 now? omg , it is 10GB...then... and worse its PATA (IDE) harddrive.
its 17 years old now, most are in the recycle bin,
it came with windows 95 or 98, (hopeless that OS)
the laptop has zero value now, so is putting a new
$50 to 100 dollar drive,is wise,?
what if there are more problems, (endless when that old)
you can not use modern, SATA drive (
just 2.5" PATA (IDE) (pata is wide parallel interface with wide ribbon cable)
here are some
http://www.pricewatch.com/price/hard_removable_drives/notebook_40gb
Jul 18, 2017 | HP 80GB NOTEBOOK HARD DRIVE KIT FOR HP...
1999 volvo s40 2.0 turbo, engine fault caused after hard accelera
well that can be a pain to deal with down unda!
Personally i think the traction control and the stumbles are not related. find out what the check engine light is, and go from there, could be as simple as a coil over, coil or set of plugs/wires or could be a gummed up throttle body, or vacuum leaks, check all the vaccum lines clean the throttle body test drive and , find the code and do some research and or post the code here and i will try to get back to you. a misfire code can be really helpful if it tells you which cylinder, if your over due for plugs just buckle down and replace them.i say
dont throw parts at it because it might not help and get expensive, but cleaning the throttle body and checking vacuum lines, replacing plugs should be preventative maintenance in my book.
use a throttle body cleaner can you can get a local parts store to clean out the throttle body. dont use carb cleaner as it could damage sensors,
if your mind is stuck on the traction control and or you get the stumbling fixed start on that here :
for the hard shifts check the transmission fluid for dark colors or burnt smells. then check out the motor mounts and trans mounts, but that should be done before moving onto the Traction control.
anyways if you suspect the traction control start with checking all the abs sensors. can use a good scanner with live data to save you time and check to see if they are all giving you good readings.
if no scanner is available you need to see if they can be removed from the hub, but be careful as they can break off inside. if they are removable from the hub check them for metal particles and make sure they arnt ground down on the ends, a bad hub will grind down the ends of them. if they look good then let me know
Good luck.
May 18, 2017 | 2002 Volvo S40
Reboot and select proper boot device
You will probably have to replace your CMOS battery (looks like a big watch battery) and check to make sure the HDD is fully plugged in. Also, I believe that if it tries to reboot again, you will want to hold down the F5 key while it is rebooting. Eventually, it should change to the system BIOS screen, and you can change the order of your boot device to one that works.
Apr 17, 2009 | Computers & Internet
Inverter KEB COMBIVERT F5 Logo
56 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
