My stb receiver coship cdvb6750 how to new software upgrade via 232 cable from internet,pls help me
4 Suggested Answers
  • 2315 Answers
SOURCE: Pansat 2500a FTA receiver
I would suggest to go here to get a lot more info on how to program this receiver.
Posted on Feb 22, 2008
amusedgeek
  • 787 Answers
SOURCE: Normal RS -232 cable
5 4 3 2 1
9 8 7 6
1 - Not Used
2 - Transmit Data (TD)
3 - Receive Data (RD)
4 - Request to Send (RTS)
5 - Clear to Send (CTS)
6 - Grounded
7 - Signal Ground (Gnd)
8 - Data Carrier Detect (DCD)
9 - Data Terminal Ready (DTR)
Posted on Sep 30, 2008
  • 163 Answers
SOURCE: need to upgrade software from 2.0 to 6.20 help
You can get the the update in the most recently released games or you could just download the update from the playstation wesite.
heres the web site:
http://www.us.playstation.com/PSP
i hope i have helped!!!! and feel free to ask me any questions
Posted on Jan 05, 2010
If I connect antenna coax to the tv in on my dish receiver, can I get ota programming on my non-digital signal ready tv with out a stb?
Hi James,
Normally, no. Most areas have gone digital-only. Here in Canada, just about everywhere has completed Phase II of our DNU (Digital Network Upgrade) regulated by the CRTC... meaning that you will need a STB to view any sort of programming.
Check with your local cable provider to see what's up. They'll know for sure.
Hope this helps!
Mar 01, 2015 | DISH Network 311 DTV Receiver
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Why
Tried changing the power supply ?
JA
Aug 11, 2014 | Televison & Video
Green color of screen
I had the same problem on my Sharp LC-32SB24U Liquid Crystal TV. When I couldn't find any solutions on this site, I looked elsewhere on the internet. I found two credible leads.
First, supposedly, this is caused by a known problem with Verizon FIOS. Apparently, there's a problem that Verizon knows about that has to do with the signal between the Set Top Box (STB) and the TV, via the HDMI cable. Other posters on other sites said that the problem is more common with the 7100 series STB's and that the problem is not as rampant on the 6400 series STB's. (Mine is a 7200 series STB.) I have not called Verizon yet, but other posters said that Verizon just says that you'll have to use a set of basic red, yellow, and white cables, versus and HDMI cable, until Verizon gets the bugs out of the system.
The other credible lead revolves around unplugging the TV for two minutes and then plugging it back in. Simple.
Here's what I did, and it worked!
I unplugged the STB and let it sit for 5 minutes. Then, when I plugged the STB back in and powered itself back up, my problem was solved! (Before I did this, I tried just unplugging my HDMI cable to rely solely on my basic connector cables, but that didn't do anything for me.)
Good luck all!
Jun 27, 2010 | Sanyo DP42848 LCD TV
AWA STB 262 doesn't work properly
bennoanddash
With all receivers, depending upon the type cable going from the receiver to the TV, the TV is set either to a channel or an input setting (if using any cable other than a coax cable). I hope this helps.
Ray Calo
DISH Network
Nov 07, 2009 | DISH Network ViP622 DVR DTV Receiver /...
How to access the usb port on a samsung le32b450
according to the user manual,the USB port is intended only for software upgrade, here are some of the supported inputs for your TV : VCR / DVD / Cable STB / Satellite STB / PVR STB / AV Receiver / Game / Camcorder / PC / DVI PC / DVI / TV / IPTV /
Blu- ray / HD DVD / DMA
Aug 29, 2009 | Samsung Televison & Video
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
PSC Duet RS-232 Handheld - help needed :(
hello The cable has taken power?
it is important to the power adapter and cable PSC.
fai photos to the cable and sends me. Then explain how to connect to xp.
hello Roberto
Jun 04, 2008 | PSC Duet RS-232 Handheld Barcode Scanner
Feb 22, 2008 | Televison & Video
Computers & Internet Logo
421 people viewed this question
David Payne
David Payne
