Question about Garden
Manual for oase aquamax 10000 - Garden
When I switch my oase pond vac on it switches off immediatly
Sounds like a ground fault or polarity issue with the connection. Check your wiring with the circuit breaker 'Off" and verify it's "off" using an electrician's screwdriver. This will also tell you when you put the power "on" whether the polarity is correct.. red is positive, black is negative, and as always, Green wire is ground.
Apr 24, 2015 | Oase Garden
Set up instructions for makita aquamax
Hello, GO to this website for manuals and setup instructions: Makita Authorized Factory Service Centers
Jun 03, 2014 | Drills
My pond pump as broke so need a pump replacment but its 10 years old aquamax 10000 where will i get spare pump from
Garden store for equivalent,need to consult a local dealer or over internet (ebay...etc).
Oct 22, 2013 | Cars & Trucks
Hi got oase filter and everything just stopped working including the pump please could you give me some advice on what it could be thank you
It could be no power, bad wires, bad controller, bad switch, bad pump. You may have something as simple as a tripped Ground Fault Circuit Interupter (GFCI) breaker or receptacle. That is what I would check first. If you reset it and it trips as soon as you turn on the pump switch then you have a ground fault in the pump. I hope this helps.
Aug 30, 2011 | Oase BioTec 10.1 Filter
Why is no hot water coming out of my Aquamax 309 NG heater? There is hot water in the tank after lifting the pressure relief valve, but no hot water is coming out of the taps What's going on?
Okay, this is new one on me, so please bear with me. From what I just read about the Aquamax is was specifically designed for areas where anti-scalding mechanizism are required. They talk about a value that has to be hooked into the hot water line. But then I could find no further information about that valve and wheather it was part of the aquamax or a separate value that is independent of the water heater.
Since the aquamax is almost twice the price of a normal water heater, it is not common here in Colorado where there is not an anti-scalding code. You might have better luck getting information from your local Aquamax suppliers.
Sorry I couldn't be of more help, and at least I learned something.
Jun 04, 2011 | Heating & Cooling
Pump runs and is fine on the output until i connect back to filter and there is not enough flow
Your filter may be clogged if not check for clogs in the fittings running between them. You will have some loss of pressure pressurizing the filter unit but it should not be a drastic loss.
Mar 30, 2011 | Oase Aquamax SF Pumps 3500 for Ponds ()
I want link panasonic nv-md 10000 user's manual ?
USB cable how to use to transfer data from camera to PC
Jun 05, 2010 | Panasonic NV-MD10000 Camcorder
OASE fountain pump fluctuates height every other day.
No there is not 2 speeds. That model is asychronous so power fluctuations can affect pumping. How clean is the plug end and how dry is the receptacle? Is there is chance a extension cord is used [code violation almost everywhere] in this hookup? Perhaps it's just debris circulation and restricting intake?
Jun 21, 2009 | Little Giant Submersible Fountain Pump
Cannot get sony bravia to work with comcast remote
manual for comcast remote says use codes 0000
or 0111 for Sony TV. BS! I used 10000 (five
digits) and it works!
Leroy
May 15, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Garden Logo
327 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
